If I threw on some affordable heads...
Originally Posted by BlackZCamaro
They typically are. Creating more cylinder pressure than a short block was designed for will eventually cause excessive wear, while not at the same rate as a FI car, but still, it will eventually begin to take its toll on the motor. The RPMS required to flow a set of heads can accelerate that wear too. The shops and companies we have all talked to warned us that the higher compression heads -WILL- put more stress on the rings, and quite possibly the bearings, and the motor will need to be re-ringed/bearinged at some point.
That is just silly. Think about this for a minute. Higher compression doesn't warrant higher rpm. RPM is a killer- sure. What does that have to do with compression though?
The fact that you make a bit more power would actually make it easier on the engine- maybe preventing the need for downshifting and higher rpms at times.
The compression ratio is irrelivant- its the physical cylinder pressure that will do any kind of damage. I've never heard of compression, in such small magnitudes, accelerating wear to a measuable quantitiy.
higher compression engines are typically higher performance engines. Untuned, knocking etc caused by improper setups can cause premature failure. This might be where the misconception comes into play.
talking about raising compression that can cause accellerated wear, does'nt installing a higher dur/lift cam increase compression in a diffrerent way then milling heads but, same diffirent increased compression? explain somebody!
fuerzaws6
fuerzaws6
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
The fact that you make a bit more power would actually make it easier on the engine- maybe preventing the need for downshifting and higher rpms at times..
The compression ratio is irrelivant- its the physical cylinder pressure that will do any kind of damage. I've never heard of compression, in such small magnitudes, accelerating wear to a measuable quantitiy..
![Icon Neutral](https://ls1tech.com/forums/images/smilies2/icon_neutral.gif)
I never said higher compression warrants higher RPM's, but in many 'high performance' engines, the cam that will produce your best power is going to be spun up higher than, say, a decent street cam.
In building an engine- you always shoot for the most compression you can attain with your fuel/spark/emissions requirements. High or low performance.
No, the fact that you are creating more power doesen't mean you are going to drive it easier, or that it is going to be easier to drive. If you're just adding power to go the same speed using only part throttle instead of WOT, then youre wasting your time and money. Think about it, the only reason we mod our cars is to go -that- much faster, not to go as fast with half the effort.
Final cylinder pressure is determined by the amount of air let in the intake valve (by the cam profile) and the static CR of the motor. Wouldn't bumping up either of these factors make a difference, especially if your cam creates a lot of cylinder pressure? That would, in turn, create more friction between your piston rings and cylinder walls. More pressure = more wear = Less mileage.
More compression = more power for the same amount of air and fuel in.
So if you need 100units of fuel to make enough power to cruise at 90mph, now you need 90 units of fuel.
if you need 500 units of fuel to accelerate at a given rate from a light, now you need 450.
High performance doesen't neccessarily mean high durability.
I am just telling BlackHawk what I have been told by numerous, reputable shops and companies over and over the past week concerning the numerous CR's in today's cyliner heads.
I dont understand why the machine shop says "with todays heads." "todays heads" blow away, in terms of combustion chambers, anything from the "old days." Better combustion chamber allows for more retarding of spark timing (or makes more peak torque with less timing) than "old heads." This means you can run more compression.
