H/C swap whats manditory/good idea
Old Dec 22, 2005 | 10:17 AM
camarokid94's Avatar
thatnks man good to know
Old Dec 22, 2005 | 01:11 PM
im still gonna have the local guy port them hes pretty good from what i hear. did my dads lt4 head. they flow pretty good.
Old Dec 22, 2005 | 01:30 PM
BlackHawk T/A's Avatar
On the topic of H/C swap, should you buy a "kit" like this?
LS1 Camshaft & Cylinder Head Swap Gasket Package includes: GM LS1 Cylinder Head Gaskets (left and right side,) GM Cylinder Head Bolts, GM Intake Manifold Gasket Set, GM Exhaust Manifold Gaskets, GM EGR Gaskets, GM Valve Cover Gaskets, GM Vapor Vent Pipe Seals, GM Water Pump Gaskets, GM Front Cover Seal, GM Front Cover Gasket, GM EGR Seals, GM Harmonic Balancer Bolt
$270!
Old Dec 22, 2005 | 06:13 PM
i will be doing that since i work at a GM dealerchip and get a rockin discount
Old Dec 22, 2005 | 08:45 PM
SmokingWS6's Avatar
You'll need a new fuel pump if you plan on spraying that much. However if you are running a wet shot, there is no need for injectors sized any larger than it needs for motor runs.
Old Dec 25, 2005 | 10:53 PM
got a racetronix pump and i have hear that 42 are easy to tune and that leaves me room to expand.
