how many detonations......?
Old Dec 20, 2005 | 07:50 PM
02TrueBlu's Avatar
Default how many detonations......?
In one minute.... How many detonations occur in an LS1 engine @ 1000 rpms?
Old Dec 20, 2005 | 08:13 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Hopefully zero, but if you're asking how many times combustion takes place; 4000.
Old Dec 20, 2005 | 10:28 PM
SUX2BU's Avatar
Actually 2,000. remember a cylinder fires every other revolution. Its not a two stroke.
Old Dec 21, 2005 | 01:10 AM
Zeus's Avatar
isn't it a spark waste system though and the coil fires twice per cycle?
Old Dec 21, 2005 | 01:45 AM
PREDATOR-Z's Avatar
You'll have 1 missfire out of 6>8 firing in a conventional plug.
0 missfires is not possible.
But detonation (pre-ignition) should be ZERO.
Old Dec 21, 2005 | 08:13 AM
LS1TECH Sponsor
You are right that it is every other rev, but look at the math.
1000 cycles firing every other revolution=500 ignitions per cylinder
500*8=4000
Old Dec 21, 2005 | 01:32 PM
SUX2BU's Avatar
500*8=4000
oops didn't see he put LS1 in the equation. i thought he was still talkin about a 4 banger like he asked in the Texas ection.
Old Dec 21, 2005 | 01:57 PM
LS1TECH Sponsor
The question is how many times combustion takes place, not ignition fires.
Old Dec 21, 2005 | 05:02 PM
Var's Avatar
Var
500*8=4000
4 combustion strokes per revolution.
4*1000 =4000. same thing different math.
http://www.cadcourse.com/winston/Dow.../aniv8-120.m1v
Old Dec 21, 2005 | 05:10 PM
Var's Avatar
Var
Some more different math
8 cylinders , firing every other revolution. (in other words only half the time)
8 * .5 x 1000 revolution = 4000
