high rpm smell (like a skunk, lol)
basically, i've posted about this problem before, but no one had an answer. pretty much when i drive my car hard, it lets off a really really sour odor when above 4k rpms. if i rev the car above 4k without that car being under load, no smell. this isn't a clutch burning smell. the tranny works great. the smell is something else, something engine related. it's been going on for at LEAST a year now, never getting better or worse.
when you pop the hood after running it, you can smell a faint smell of antifreeze burning, but the car looses very little (if any) coolant. i would guess there is a small leak, but it's not something that has dripped on the ground before, and i can never see a trace of it underneath the hood.
the car drives fine. i could guarantee the power has not changed any. nothing makes weird noises or shakes or anything. the only thing is that an awful smell protrudes from underneath the hood at high rpms.
any guessers out there? i seem to have the weirdest car problems ever, by the way....
skunk/rotten egg smell with cats run some catalytic converter cleaner through it . I run with cats and when i run it hard to clean them out it puts off the classic egg smell. there not clogged i just dont get on it much in the winter.
Originally Posted by XtrmLS1spd
Mine is doing the exact same thing only during WOT. Very weird to say the least. I am not running cats though.
it has nothing to do with cats or no cats. like i said, i was told it was one of three things:
1. battery. nope, i changed mine with a brand new one; no deviation in smell.
2. clutch. nope, i changed mine with a brand new one; no deviation in smell.
3. cats. nope, i change mine with brand new ones; no deviation in smell.
the only conclusion i can make is that it could coincide with the antifreeze i smell underneath my hood after i drive; however, the WOT smell is nothing like the smell of antifreeze.
do you smell an antifreeze smell after you have run your car?
anyone else have any ideas?
what does a blown head gasket smell like? i would think after smelling the same for a year now without a change in performance, a blown head gasket would have either ruptured or gotten much worse, no? not only that, but there is no foamy residue on the dipstick or in the radiator area, which is generally a characteristic of a leaky head gasket.
Speaking of foamy residue from oil, I actually do get that occasionally where the oil is poured in. maybe like once every 2-3 months. Though, it is no where on the dipstick. But, I have no loss in performance. Any thoughts on what causes that?
I smell no antifreeze whatsoever.
My '91 smelled the same way for a year after I put a cat on it. Only when you beat on it too.
I'm pretty sure it's caused by the cat and you'll probably have to get used to it.
Maybe there's some other way a lot of sulfur got into your fuel supply? Mabye try a different gas station.
Maybe your running real rich at WOT and its causing your cats to over heat? Might also trace all your coolant lines to see if there is a leak coming from a connection point? Have your done the TB bypass mod?
there is certainly a coolant leak, i just can't pin it down. it loses about a cup of coolant every 2 weeks. no drips or wet spots though, so wherever it may be leaking it is also evaporating before i can find it.
and yes, i did the TB bypass mod. maybe the car is running rich, i dunno. it's been autotapped since the smell has been apparent, and the car ran perfect.
another thing, the more windows/t-tops that are open/off, the more i notice the smell. with the windows up and the tops on and air on, i don't smell it any whatsoever. with the tops off and windows down....VERY potent.
Originally Posted by tuffluck
only does it under load. tried the revving at 4k+ rpms and it does nothing...no smell unless the car is being forced to move, in other words.
Originally Posted by Quickin
Only under load eh? Thats wierd in itself. Got to be something coming out under pressure and burning on something to make the smell. Man, you may have to check it with a flashlight on a dyno.
maybe it could be an accessory? then again, you'd think an accessory would have the same problem of smelling bad regardless of if the car were in load or in neutral. that makes me think the problem is tranny related, but the only thing it could have been was replaced (the clutch). i have no idea. the car only has 54k miles on it.
the weirdest part is that this has been going on for about a year or so now. the antifreeze hadn't started leaking until about 3 months ago. so the antifreeze really cannot have much to do with this issue. the car uses little oil, too, so it can't really be that. there are really no fluids in use at WOT that could make this smell, no matter how much they were burning.
Check the motor mounts, maybe one is broken, maybe a pulley is loose or out of alignment with the rest. Maybe when you hit it the water pump drips some and onto the belt or maybe some water drips from the TB water hose onto the belts
Well ,when the engine is under load its also all jacked up and everything actually moves a little bit from the torque. Maybe something is slightly rubbing when the engine is jacked to the right when you hit the gas. I think its jacked to the right, maybe its the left.
