LS2 heads
Old Dec 26, 2005 | 02:27 PM
IVRedZ28LS1's Avatar
Default LS2 heads
Will stock LS2 heads bolt up to a stock LS1 Gen III block on a 98 camaro? Which head gaskets to use? Cometic? plan on porting out the LS2 heads.
Old Dec 26, 2005 | 02:45 PM
WsSickLs6's Avatar
LS2 heads are LS6 heads...so they will work
Old Dec 26, 2005 | 02:54 PM
GuitsBoy's Avatar
Theyll work, but expect to only see a mere 10 or so HP gain. Unless youre getting these for a super bargain, look into some of the sponsor's ported heads. Both patriot and livernois have sub $1K CNC ported 234 heads. 243 is the casting number for the ls2/ls6 head.
Old Dec 26, 2005 | 03:42 PM
Thanks guys.
Old Dec 26, 2005 | 05:58 PM
oange ss's Avatar
i think LS2 heads have a revised 12 degree valve angle
Old Dec 26, 2005 | 10:31 PM
GuitsBoy's Avatar
not true. The new ls7 heads have a 12 degree valve angle, but the ls2 heads are 243 castings, same exact casting and same 15 degree angle valves as the ls6 heads
Old Dec 26, 2005 | 10:35 PM
oange ss's Avatar
yeah, i had it backwards and ETP heads are 11
Old Dec 26, 2005 | 10:36 PM
GuitsBoy's Avatar
Correct! Those ETPs look siiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiick
Old Dec 27, 2005 | 09:40 AM
Gunnar@Patriot's Avatar
We have these castings new bare for $645.00 pair. We can do a set of ported heads bare for $845.00 per pair.
