when to change lifters
Old Dec 26, 2005 | 04:40 PM
50chevy's Avatar
Default when to change lifters
i have a 2001 5.3 with 59k miles and i am going to be getting a new cam for it, are the lifters reuseable at this mileage or a should i replace them.
Old Dec 26, 2005 | 05:25 PM
BlackHawk T/A's Avatar
They are, but it doesn't hurt to get a new set I guess...
I am replacing mine but it costs around $200. Since I am doing heads/cam i'd like new lifters in there also. Mine have 75k.
Old Dec 26, 2005 | 05:56 PM
CBX's Avatar
CBX
I did the same at 56,000.
Old Dec 26, 2005 | 09:31 PM
ArcticZ28's Avatar
This question falls into two different categories of thinking:
1) if it ain't broke, don't fix it
2) why not upgrade it since you're already in there
The first category is for those who have replaced lifters when they didn't necessarily need to and then had problems with PITA replacement lifters (*ahem* comp r lifters *ahem). The second is for those who have had luck with their replacement lifters (a lot of times, comp oe replacements). It's basically up to you, it's like replacing the oil pump when doing a cam swap.
Old Dec 26, 2005 | 10:54 PM
67Ranger's Avatar
IMO, if you arent pulling the heads, its a lot of extra work.
Old Dec 27, 2005 | 02:16 AM
TINKRD's Avatar
replacing mine while the heads are pulled. motor has 133,xxx miles. I fig its about time to change'em anyways.
Old Dec 27, 2005 | 08:14 AM
GuitsBoy's Avatar
LOL! If he is replacing the lifters, then he clearly IS going to pull the heads!
Old Dec 27, 2005 | 11:02 AM
67Ranger's Avatar
he said that he was changing the cam... nothing about swaping the heads. Most people can swap a cam without pulling the heads, and that was what i was saying.
Old Dec 27, 2005 | 11:15 AM
WS6FirebirdTA00's Avatar
keep the stock ones
Old Dec 27, 2005 | 11:19 AM
Fenster's Avatar
I don't totally agree w/ that last statment. I would much rather and WOULD replace the oil pump over the lifters. Not just b/c I was in there but b/c w/ the cam, higher rpms etc, you need to ENSURE that oil pressure and failure isn't an issue. W/ the lifters, if they aren't a problem don't worry about it IMO. Now if you have the spare cash and need the piece of mind, then put new ones in. I'd just go w/ stocker replacments though.
Old Dec 27, 2005 | 11:26 AM
also depends on what year your car is for oil pump swap
Old Dec 27, 2005 | 12:27 PM
GuitsBoy's Avatar
I know dude, it was a joke. A play on your wording. I was playing on the fact that in order to replace the lifters you need to pull the heads.
Old Dec 27, 2005 | 03:10 PM
ArcticZ28's Avatar
Plenty of people run stock oil pumps after cam swaps. It's not mandatory to change the pump at all, especially if you have the ls6 pump from the start.
Old Dec 27, 2005 | 04:14 PM
TAQuickness's Avatar
cheap fast reliable - pick two
Old Dec 27, 2005 | 04:23 PM
GuitsBoy's Avatar
Youre generous. Id have said pick only one.
