Lifter Preload Help!!!!
Old Dec 28, 2005 | 07:50 PM
vettenuts's Avatar
Is that 0.075 at the rocker thread? If so, with stock rockers, you need to multiply by 2.54/1.54 to get the actual preload at the lifter.
Old Dec 28, 2005 | 07:53 PM
Haans249's Avatar
The best way to get the proper preload on these lifters, is to install the lifter as normal, then drop in an adjustable pushrod length checker, then, install your rocker and trq down to 22ftlbs. Then adjust the pushrod till you have zero lash at the rocker base, remove, then measure. Then add .030 to that measurement. That got me to .035 preload, so its a good method.
Adrian
EDIT: forgot to mention that you have to make sure you're on the base circle of the cam lobe you're measuring on...
Old Dec 28, 2005 | 08:37 PM
white2001s10's Avatar
Originally Posted by John02SS
Had a set made from Crane and they were total GARBAGE. Varied .030 from shortest to longest and was told that is as good as it gets. It is been a hassle!
holy hell!
They made you an extra special set of variable length pushrods. I bet you feel really special.
Old Dec 28, 2005 | 09:59 PM
John02SS's Avatar
Originally Posted by white2001s10
holy hell!
I was a lil surprised by it to say the least! I expected more I guess! They were truely custom though!
Old Dec 29, 2005 | 05:16 AM
Viper's Avatar
WHAT??? I have never seen that yet....
Old Dec 29, 2005 | 07:49 AM
vettenuts's Avatar
Here is my figuring. The rocker tip is on the valve spring. The valve spring won't compress (assuming you are on the base circle of the cam all of the preload will be at the lifter). As you tighten the rocker, it will pivot on the valve spring through the lever ratio because you have two similar triangles, so the ratio is the distance from the valve tip to the pivot point and the distance from the valve tip to the pushrod. The stock rocker is about 1.54 rocker ratio at rest, so the ratio is 2.54/1.54 or approximately 1.65 times the rocker movement.
Hope this explains it, but it makes sense that if you tighten the rocker down the pushrod will move more than the rocker pivot point.
Old Dec 29, 2005 | 08:52 AM
CAT3's Avatar
Restricted User
CAT3,
What preload do you have on the Morels now? I have .075 ( if a 1/4 turn on a stock rocker = .015, then 1.25 turns = .075, search is down ) but need to bring it down to .030.
I can check again when I get home next week, but honestly not sure right now.
Whats the operating range of the Morels?
Old Dec 29, 2005 | 08:58 AM
Viper's Avatar
They say .025-.035 cold. Much tighter than stock or comp replacement.
