LSK lobes...
Just to add another wild card: how about a smaller, emissions cam with a supercharger? You could make more power and be emissions legal.
You would need a blow off valve, however you would have very sharp throttle response.
If going this route, you probably want to start with slightly lower compression.
P.S.
This is a pretty expensive motor (big heads, Jesel, Harrop), what are you doing for the bottom end? I would have either Callies or Crower make up the bottom end: either Crower dihedral light crank and maxilight rods or calles magnum xl with carillo rods. In either case a custom CP, Wiesco, or J&E piston. Tool steel pins. The crank manufacturer will build and balance the crank for the correct bobweight. Probably should specify a no-hole balance. I like the Callies induction hardening of the crank, however I prefer the design of the maxi-light rods and some of the details on the Crower crank.
Either could also whip up a set of Ti rods for another $2k or so, probably saving 150gms/rod at this power level.
DAPSUPRSLO, I understand exactlly what your saying, but, in your applcation, you have the intake as a limiting factor. You will maximize your under curve power, but with the smaller cubes, it'lll want to rev, which it won't be able to, because it is intake limited. The motor will peak far before it could because of lack of being able to get the proper amount of air. So, I ask, why would you want to limit yourself in the intake department? Kinda like ya'll asking me why I would limit myself in the cam department?
Keep this stuff coming guys, it's very informative, and I'm enjoying the conversation.
Cary, Craig, don't the ET heads support that?
I used the Harrop 55 mm intake in a Dynomation sim for a 7.0 L. all-out road race engine with ET's 240 cc C5R heads , 0.750"/0.630" lift, 276/284 @ 0.050", 114 LCA solid roller cam, 14:1 CR, 2.0" to 2.2" ID stepped headers and Burns-style collectors. The estimated power from the very first shot was far enough over 800 HP @ 7,000 RPM that I won't be specific for fear of being jeered off the thread.
I should know within the month if the customer will build it; he threw out the approximate specs but was expecting 'only' ~ 720 HP and now may choose to go much more conservative. )o:b
If you insist on hydraulic lifters (and you can always change that), you may as well use the biggest lobes on both intake and exhaust. You may be happier retarding the cam a little...say 263/263 110/+2.
You have program that can model a merge collector? Those numbers look very reasonable for that spec. Big solid cam, lots of lift, high compression. I'm getting 774hp @ 6500 rpm for it, but could have some of the specs wrong. Very flat torque curve from 4700 to 6500, with only a slight (15%) drop to 7000. Playing with intake runner length and diameter can get it over 800, at some loss of low end of the power curve.
I have to go back to work now.
As for the cam selection, increasing the intake duration and subtracting th eLSA and IVC are going to drastically decrease my DCR. The specs you have above would drop me to 7.7 DCR, when I'm trying to stay up around 8.3-8.5. Plus I wanted a little extra on the exaust duration incase my exaust became a hindering factor. The biggest header I can get on an F-body is the Kooks 1 7/8 stepped to 2", which is what I have. If I can fit a 3 1/2 inch X-pipe exaust under the car, I may not be as worried about it. It's possible that I may just stick with the 3" X system though.
As a few different threads running around today indicate, a more aggressive cam can have less overlap with more duration at .050. For example, a 242/242 106 Xtreme Street Roller would be like a 238/240 114 XE-R.
I'm not sure how DCR varies over cylinder size. However, the tool I'm using seems to prefer a later ICV. Arount 88 ABDC.
http://users3.ev1.net/~black_ops/video/242-106.mpg
Your theory on the overlap is interesting. All the more reason for us to know which lobes they use in Aussie.
As for the DCR, I'm looking for an IVC of around 76-78 @ .006". Should make for some violent mid-range power.
EDIT: After doing some searching, it looks like the Aussies use the same comp lobes we do. They seem to be pretty popular over there. I also found a thread, that you started David, that had alot of good info on the ITB's.
Throttle response will be fantastic. The throttle plate is just a few inches from the valve. However, the overlap is within a single cylinder. What is the theory behind individual TBs affecting idle?
The overlap question is probably at the root of the LS9 being an SC engine. Clearly, there is 100hp on the table with the LS7, unreachable for emissions reasons. With SC, they can get the flow and leave the overlap low. In fact, it advantageous to leave the overlap low.
I wonder why they didn't spring for a solid cam. That would have let do 240/252 with similar lift and the same overlap and ICV (vs. 211/230). That would be interesting, a set of Jesel or T&D adjustable shaft rockers and a 240/252 119/-4 Xtreme Street Roller for High Lift. Might need a little more spring on the seat, although the lift is the same.
Compared to a 108/+4 setup, it has the same evo and ivc as a 261/255. Or 257/259 108/0.
For a given displacement, the better flowing head needs less. However (I love that word), the bigger head gets much of its advantage at larger valve openings. The 265 has minimal advantage at .5" (0-5%) and no advantage below that. At .7 the difference is large(over 15%). And the bigger port would have trouble achieving adequate flow velocity at low speeds, further hindered by high overlap.
What sort of profile does ET suggest for your application? With the Harrop intake, you will have one of the prettiest ET installations. And with a 454, pretty high numbers.
