Oil Pump installation Question
I'm only going by what was on the video tape I made of the show. I guess the intent is that if the pump housing is centered in relation to crank sprocket/oil pump drive, the the georotor in the pump will also be properly aligned when you put it back in pump housing. I don't really know. I was the one asking the question, remember?
Thanks, Gary
Thanks, Gary
Also, as stated above there is no mention of a special tool or using Loctite on housing bolts at least in the '98 GM service manual.
That is the correct way to do it
I don't agree with this statement at all. You can certainly assemble the pump and **** the housing so it is rubbing against the lower timing gear/oil pump drive. That is why GM sells a tool to install it, because for safety sake it should be centered so there is no housing wear. If you don't believe me put the oil pump on put all 4 bolts in a tighten them so you can still move the pump and you will see there is still room for movement to contact the pump housing
Thanks JnJSpdShop
Update: I finished everything up, reassembled the pump loctited the bolts etc. As a final check I slide the .002" feeler gauge between the housing and high part of the spline on crank sprocket/ oil pump drive, and using a flashlight I could see it protrude from the back side of the pump. I repeated this step for all six of the splines. so I know nothing moved. If you had six strips of .002" shim stock you could probably center the pump without disassembling it, but taking it apart makes it easy to see what your doing.
There is a somewhat ironic twist to this insight. My first post was intended to share the fact that anyone willing to risk disassembly of their oil pump could simplify proper seating of the o-ring. The irony is that disassembly is necessary to directly ensure there is no interference between the crank sprocket and the pump housing and therefore, disassembly should be the standard procedure.
This has been a valuable lesson for me. Thanks to everyone who has contributed to this discussion.
-Gary
Thanks 618Hawk!! Both sides of the inner drive gear apprear identical to me. I was just hoping maybe some of folks that disassembled and ported their own oil pumps would chime in to confirm.
Thanks again!
If it moves enough to rattle (.001-.002) it's fine. If it is so tight that it will not move, start over.
. My pump would not rotate either, took it apart and reinstalled it like 3 times before realized it wasn't working this way. I had to torque the bolts down a little, rotate the crank, tighten a little, and rotate the crank until my bolts were fully tightened and the pump rotated fine.Philip S.
also drill the cam-sprockets retaining bolts for safety wire, RED locktite, Ive heard (read) fairly frequent that this bolts came loose.
with the z06-1 pumps, thera are THE SAME dont bother to hear BS from someone selling a "special" ls6 pump. for clarification PERHAPS later production pumps got more machining attention...
also when installing oil pump do not slap it, measure it.... with gerotor removed (pump disasembled) instal pump body to crank snout with two bolts finger tight, slide two gap feelers diametrally opossite of 0.002" Th. this WILL center pump body, tighten up the four bolts, then drench the gerotor in 90 oil (!) (this will insure sucking power when first starting) assemble the pump....
prelube your (new!) oil filter install it, put cheap 10W oil
START..... PRAY..... oil needle jumps..... GOOOOOOD JOB!!!!!!!
use the car easy for about two hours... drop oil...
new oil (favorite good quality) new filter.....
E-N-J-O-Y ! ! ! ! ! !
GOOD LUCK!
