Oil Pump installation Question
It's not a job a want to do twice, so I want to get it right the first time. Also has anyone done a writeup using this procedure?
Thanks for any help.
I have never seen any of our engine builders doing that. Just wondering, is it our pump?
I would say you could probaly get away with out doing it but whay take a chance.
Does it make any difference which way you install the drive gear ie inner smaller gear? It appears you can flip it either way.
I searched through some video and finally found that episode. They removed the georotor and checked for .002" clearance between the driver and pump housing all the way around. At least according to them, it is a very important step to prevent the georotor from destroying itself and sending bits of metal through the engine. I suppose it can't hurt to check it.
Thanks for all the replies guys! I've learned alot from this forum.
