School me regarding spring wear with example inside using two Lunati grinds
Duration @.050 IN/EX: 230/237
Gross Valve Lift IN/EX: .544"/.543"
Lobe Sep Angle / Intake Ctr Line: 112/108
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2800-6000
68/49
Duration @.050 IN/EX: 237/242
Gross Valve Lift IN/EX: .595"/.595"
RPM Range: 3000-6500
61/59
Just as an educational example, would the softer lobes of the higher lift cam be easier on valve springs than the aggressive exhaust lobe of the lower lift cam, given the durations we're looking at? The subtractions of .050 from .006 are bolded.
I'm forcing myself to learn how to read a cam card (beyond .050 duration, lift and lsa) and learn more about valve events. After 6K posts, you'd expect me to know a 'lil more beyond calling out "F13 is what you need!"
