Lifter surprise????
Old Jan 5, 2006 | 06:54 AM
Wet 1's Avatar
How do the factory encapsulated lifters compare to the aftermarket lifters for high perf. use?
Old Jan 5, 2006 | 08:13 AM
GuitsBoy's Avatar
Here were mine from a few months ago:
SCARBROW: What were you running and do you have any theories on what could have caused your lifters to flake apart? Did you cam bolts ever loosen allowing the cam to walk?
Old Jan 5, 2006 | 09:18 AM
scarbrow's Avatar
i have no idea why they came apart, i just bought the car, and i got it cheap because the dealer who had it said that they thought it had a bent pushrod making noise. when i went to drive it i kind of thought the same thing because of the ticking it was making. i am not done pulling the motor apart, so i have no idea if a cam bolt is loose or not.
Originally Posted by Teutonic Speedracer
Wow....and I thought my lifter failed.....yours looks about 5X worse than mine. Any other issues with your motor?
Scarbrow's pics show what the non-encapsulated version looks like.
still tearing into it.
Old Jan 5, 2006 | 09:34 AM
GuitsBoy's Avatar
Well if the cam had walked, it usually sets a SES light for "cam position sensor high signal" or some such. Hopefully youre in the clear. Did it chew up any lobes on your cam? How man miles on the car and what cam?
Old Jan 5, 2006 | 09:48 AM
scarbrow's Avatar
stock cam, all stock car 102K, i did rip on it once through 1st and 2nd, and the check SES light started flashing for a while, that was the last time i drove it, but the light went off after about a minute, so i think it might have been the knock sensor since the motor got to ticking very loud.
i am pretty sure that the cam lobe is chewed up too
Old Jan 5, 2006 | 12:02 PM
Teutonic Speedracer's Avatar
My Failure:
Parts:
Original Lifters (stock non-encapsulated), 918 Springs, Ti Retainers, 216/220 .525”/.532” cam, CC hardened pushrods, 6660rpm limit. Lifters have 32k miles (15k w/cam/springs, 4k track miles).
Background:
Noticed one small pieces of metal on drain plug after Summit Point track weekend. Took valve covers off, checked valvetrain (rockers, springs, etc.). Everything looked fine. Attended another track weekend at Watkins Glen (~150 roadrace miles).—Car performed fine. Noticed a clicking/tapping sound when taking car off trailer and pulling in garage. I then had my buddy listen to the car while idling. He thought it sounded like a lifter on #X cylinder. We then pulled the fuel pump fuse and cranked the motor over a few times, he definitely leaned towards the same cylinder. After taking the heads off, I found ONE lifter to have a bunch of flat spots on it like it had been skipping, and some rough material on the edge of the wheel. That cam lobe on the cam was also missing a decent amount of material (the cam was 5X worse than the lifter). The plastic lifter tray for that pair of lifters was slightly deformed enough to allow the lifter to rotate ~10-15degrees and allow the lifter to be very loose in the tray. A few other lifter trays showed a bit of wear, but nothing significant.
Possible causes:
I’ve talked over the situation about my lifter with my mechanic/racer/engineer buddy. He came up with a few ideas for failure:
1. Lifter bore holes in block are slightly off (not drilled at the proper angle from the factory)
2. Cam lobe failure caused the lifter to fail.
3. Weak valve spring allowed the lifter to skip on the cam for a while doing damage to both the lifter and the cam.
4. Plastic lifter trays deformed and allowed the lifter to rotate ~10 degrees on the cam lobe.
5. Combination of all of the above.
Upgrades:
I’ve done the following in order to help the situation and prevent it from happening again:
1. New Comp OEM (850-16) Lifters. (supposedly similar to stock, but better, encapsulated)
2. LS2 Lifter Trays. Seem a bit beefier than the LS1’s. (need (4) at about $7/piece)
3. ¼” holes drilled in lifter trays to allow oil to be relieved at high rpm.
4. New 918 Springs (this may have been a reason for failure….I’ve yet to get my springs checked to see if they were in spec, the one that failed in particular.
5. LS6 Lightweight Valves (reduce load on valvetrain)
Old Jan 5, 2006 | 01:19 PM
Zick's Avatar
Originally Posted by Dipstick
This is what came out of my 2000. Is this encapsulated?
I had these kind in my 98' when I tore it down So unless the P.O. changed them I don't know what to think.
Old Jan 5, 2006 | 03:57 PM
99sprayjunkie's Avatar
Originally Posted by 2scoot
GM offered two types of lifers in the LSX series motors, the first one was installed in the LS1 motors starting in 97 and ended in 2000. These lifters were a split/non-encapsulated type of lifter that most builders believed were not very durable for hig HP motors. The second type of lifter was a fully encapsulated type; meaning the roller was mostly surrounded by the lifter itself. These are considered the most durable and have been used in motors with high lift and HP figures well above 1200 HP.
So today I'm tearing apart my 2004 LS6 motor and guess what? It has the older type of lifter installed!!! WTF?? Anyone else have this issue?
This is my third LSX motor and the first one I've seen with this.
So now I'm thinking I have to purchase a set of new lifters...................
The two 99 motors Ive torn down each had the fully encapsulated type,maybe they were first,non-encapsulated second-seems to be the trend.
Old Jan 5, 2006 | 04:09 PM
Cstraub's Avatar
I would venture to say one is a Delphi and one is an Eaton lifter. Both suppliers to GM.
I would be curious to know the wheel diameters on each. I would assume the encapsulated is smaller in diameter. If so and the cam is designed for a .720" wheel then this will effect the duration numbers.
Old Jan 5, 2006 | 05:13 PM
My stock (non-encapsulated) lifters off my 01 Z28 just measured in at .700" wheel diameter.
I can't measure the wheel on the new Comp 850-16's, but to the inside of the encapsulating part of the body was .720", so I would venture to say the wheel is in the .700"-.710" range?
Old Jan 5, 2006 | 06:36 PM
Dipstick's Avatar
The encapsulated ones are .700" diameter. My guess is that GM found out they could save money with the non-encap ones since it takes is less metal to make it.
Old Jan 5, 2006 | 08:39 PM
  #32
.02 here, .02 there......unfortunately it adds up. I wish the timing chain damper had come from the factory on LS1's. It now does on LS2's and LS7's.
Old Jan 5, 2006 | 09:27 PM
  #33
2scoot's Avatar
Wow those lifters are smoked! I have to side with the mechanics findings on this. It looks like there were other conditions that caused roller failure. One thing to note about a difference between the two types of lifter is that the fully encapsulated type has the roller and bearings enclosed in the casing if you will. This could possibly prevent damage to the motor in case of failure. Here is the part number for a valve lifter (GM)17122490. This again is for a 2004 LS6.
The stock lifter have been proven up to 7000 rpm and well over 800 hp. If I had the cash and were swapping out a cam I would go with the Schubecks lifters. But if I were on a budget, Mellings or the GM's.
Old Jan 5, 2006 | 09:45 PM
  #34
Dipstick's Avatar
I didn't specify what year, just ordered (GM)17122490 and got the encapsulated one that came out of my 2000.
Old Jan 9, 2006 | 03:51 PM
  #35
vettenuts's Avatar
I think that is most likely the cause.
Do you have the LS2 part number for the lifter trays, were they a plug in fit?
Old Jan 9, 2006 | 04:23 PM
  #36
I have not put it in yet, but understand it to be a drop in item. They are in drilled and ready (waiting in the bag in the toolbox to drop in).
P/N1259365-LS2, P/N12551182-LS1
-Dennis
Old Jan 9, 2006 | 04:52 PM
  #37
Randy WS6's Avatar
I balt a set of encapsulated lifter from Advance Auto the brand is Seal Power and i put the same lifter in my all forged LS6 348cid over two years a go and replaced the cam for a T-Rex and the cam that cam out looked perfect and a good thing about Advance is they will match price any body even e-bay can you believe that ,there regular price is 16.00 a piece and i got them for a 108.00 a set of 16 Ive cranked these lifter over 7600 rpm many times and never had any problems or float out
Old Jan 12, 2006 | 03:46 PM
  #38
2scoot's Avatar
Heres some more info:
GM doesnt differentiate between the two types of lifters, both are the same part number. Went to a dealership today to find this out. Also went to Auto Zone today to see what they had. They carried Mellings (fully encapsulated) for $13.99 ea. Not bad if you need em in a hurry but I called Futural and they have the Mellings on sale for $165 a set! Thats a good deal.
Along the same lines: The LS motor hemmorages oil internaly due to it being aluminum and that it expands quite a bit more than CI. Becasue of this the oil pressure is increased (this is the reason most go to a ported oil pump) to compensate for the increased clearances. Now back to the lifters...the non-encapsulated due to design will make the condition even worse. This is due to the positioning of the lifter body in the bore, even more so with a higher lift cam;so the NE type will show less oil pressure. When we changed to a encapsulated type the oil pressure remained high and show very little drop when hot, everything else remained constant. Another good reason to switch.
Old Jan 12, 2006 | 04:07 PM
  #39
oange ss's Avatar
now you tell me
Old Jan 12, 2006 | 04:32 PM
  #40
vettenuts's Avatar
Two questions to consider:
1. At what ramp rate/lift does the encapsulation hit the ramp?
2. What is the roller size of each?
If the roller is different, it will spin faster, and the ramp of the cam will be interpreted differently to the valve.
I don't understand this at all. What does aluminum block vs. iron block have to do with oil pressure and the need for a ported oil pump? I think the increase in oil pressure was more likely due to the lifter body design rather than the mere fact it was encapsulated, or is that what was meant.
