Will this cam work w/stock pistons, no valve relief?
Originally Posted by bigdsz
I think what you guys just don't get is that a cam can fit, but how close of a fit. I've got a Comp XER 228/230 112+2, a lot of people would say it will fit, well I only had .045 clearance at 8* btdc. Intake valves should have a minimum of .080. If I leave it like that and don't notch what happens if I float the valves or have an over rev situation. It's better to be safe than sorry.
We recently pulled the AFR heads off a friend of mines car with a 224/228, guess what there were little arcs where the intakes had just bearily touched the pistons and cleaned the carbon off.
The 224/228 was a Comp XER I think 114+0. I know that cam would normally fit, the guy probably had an over rev and touched the pistons. All I am saying is that with these larger cams , they should be degreed in and clearances checked 8-10* before and 8-10* after TDC. Too many guys are not notching the pistons when they should be. Just because it fits doesn't mean it's fitting right.
I have stock heads on my car. If I bought this cam I would be doing springs, retainers, rods, everything. I dont usually miss shifts, and Im going to get a Pro5.0 to help with that. And ontop of that, I usually shift close to 6k RPMs. But Im going to have my rev limiter raised so that I wont bounce off the rev limiter. Even though Im raising the rev limit, Im still going to shift at the same RPM though so I have a lil space of safety. And this may be a really stupid question, but is there a different gasket I could get to help give me even a little bit more clearance?
But I just need a simple yes or no on whether this cam will fit. Stock heads, no relief. If it absolutely wont then Im just going to look at a G5x3 I guess?
For starters do you have LT's? If you do not, and I don't see them in your sig, then you would be severely limiting that cam. I would not install that cam without notching. Why don't you go see Mike Norris at Next Level Performance in Alatmonte Springs for some insight. You will need him for a dyno and tune after the install anyway.
Originally Posted by nexvctm2001ss
think the biggest lift is 601 before you have to fly cut the piston not sure though
my buddy just said you will have to cut the piston
Well I hope your buddy also knows that lift has almost NOTHING to do with P/V clearence.
Please dont make posts like 601 if the most lift if you dont know that for sure.
If misleads people and puts wrong information out there.
Nothing against you just pointing this out 1 more time so new members dont get the wrong info.
Also I believe the cam will fit fine.
Set you rev limited at 67-6800 and dont be scared to shift around 6350 or so. There is no point to run a cam this large if your not going to take advantage of the power at top.
If you going to shift at 6000 I would go with a smaller cam that will be much more driveable and give you awsome mid range power. Something like a 224/228.
Both cams will pull very similar to 5800 RPM's give or take but then the 232/240 cam will really start to out pull the 224/228 cam. If you shifting at 6000 you will never get the full benifits of the top end power so why use that big of a cam??
this almost identical to a G5X2 except it has just 2 more degrees of duration on the intake. it will work just fine N/A in your car but it wont be a great boost cam. i didnt have to flycut with my cam, and there are bigger cams out there than mine that work fine without having to do that. like the TREX, G5X4, G5X3, TSP Magic Stick, Futral F15(Ron Jeremy), and many others.
Im going to go with the cam. Im hearing from a lot more places that this will work so I think ill go with it. As for revving to 6300rpms, Ill do that once I get use to the cam and am sure I wont f' up and miss a shift and hit the rev limiter at all.
