Dot to dot timig problem!
Old Jan 2, 2006 | 02:55 PM
CBX's Avatar
CBX
Originally Posted by TA TECH
Yes it would be TDC with the factory sprocket! I always use the LS2 chain on all the other stuff I do so this certain car already had the double rollmaster chain! Just wished we would have know about the way the company where the short block came from had assembled it and the make shift marks!But yes dot to dot factory sprockets are good plus ya ain't got to really remove them!
Got it. So it's the cam sensor that determines the cycle.
Old Jan 2, 2006 | 03:28 PM
TA TECH's Avatar
Factory spockets yes!Well that and the PCM!
Old Jan 2, 2006 | 03:36 PM
Bo White's Avatar
So the LS2 timing set is a direct replacement? Ive been wonderin about this- it should be.
Old Jan 2, 2006 | 03:47 PM
CBX's Avatar
CBX
Yes, it's just beefier.
Old Jan 2, 2006 | 03:50 PM
Bo White's Avatar
Thanx CBX, this is probably my next mod . Got my springs and pushrods swapped out over the weekend and so this will be next more than likely.
Old Jan 2, 2006 | 03:55 PM
CBX's Avatar
CBX
Can't beat it for the money.
