figuring out compression ratio
Old Jan 5, 2006 | 11:59 PM
jonus079's Avatar
Default figuring out compression ratio
just wonder how i would go about calculating the compression ratio of an engine with stock head. im trying to figure what size piston would be best suited for a turbo or blower applications. i did a search and found some genral background of pistons. just would like to know how exactly could i calculate the aprox. ratio. i know i want to get pistons <~-10 and id like the cr to be around 8.5:1. also what does compression hieght mean? any input would help.
Old Jan 6, 2006 | 12:14 AM
WS6store.com's Avatar
LS1TECH.com Sponsor
With -10cc pistons with a .040" compressed gasket you will be around 9.3 CR. This is with the piston-deck height .002". If you went up to say a .050" it would drop it to about 9.1 CR. A -15cc piston will give you about 8.4 CR with the same piston-deck height and a gasket thickness of .040".
Old Jan 6, 2006 | 10:31 AM
jonus079's Avatar
just a quick note. with this kit:
http://www.lethalperformance.com/pag...mpression.html
the pistons are -28.50 but the compression ratio is still about 9:1. is this because the rods are not stock so it changes?
Old Jan 6, 2006 | 10:49 AM
PREDATOR-Z's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
Old Jan 6, 2006 | 01:00 PM
jonus079's Avatar
ahhhhhh just what i was looking for...thank you
