Another Help Me Pick A Cam Thread
Old Jan 6, 2006 | 08:55 PM
2000RedZ's Avatar
Default Another Help Me Pick A Cam Thread
I'm going to change my current cam out for something bigger, the cams I have in mind are:
TSP 231/237, .598/.595 112/114, 1700-6500 RPM Power Band
TSP 233/239, .595"/.603" 112/113/114, 1900-6500 RPM Power Band
TSP Torquer V.2, 232/234, .595/.598, 112/113/114, 1800-6400 RPM Power Band
FMS F13, 230"/232" .595"/.585" 112/114, 2500-6800 RPM range
Which one of these cams will get me the fastest 1/4mi. time, with mods. in sig and ported throttle body, ASP underdrive pulley, and 3.73 gears, TSP True Duals, and a TNT F1 kit in the future. Also will appreciate any other cams that might work well with my setup.
Thanks
Old Jan 6, 2006 | 09:01 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Torquer 2
Old Jan 6, 2006 | 09:36 PM
BriancWS6's Avatar
If all your looking for is peak power then either the 233/239 or the torquer. The TSP 231/237 is ground off Lunati lobes, and are old school and lazy compared to the newer XER style. So that would be my last choice.
I am seriously thinking about the F13 for my heads/cam setup. Either that or the F14, I am torn between those two cams. The F14 and the torquer are very similiar as far as @.050 and lift specs go.
Good luck man!
