Comp "r" yay or nay
Old Jan 10, 2006 | 12:13 PM
badpewter-z's Avatar
LS1TECH Sponsor
ive had comp r's for about 10k miles with no issues but they are noisyier than a regualr setup
Old Jan 10, 2006 | 06:47 PM
MNR-0's Avatar
comp-R lifters here too. Seem to work OK. 212-220 high lift cam and crane 1.8RRs. The engine is a little noisier due to the lift and acceleration rate of the valves, but otherwise it runs sweet. No high RPM valve float at all.
918s + crane 1.8RRs are holding up well.
Old Jan 10, 2006 | 08:45 PM
roughneck427's Avatar
Well from the comments that have been made in here and a few other forums i think im gonna go ahead and use them.It makes sense that if you have the lifter preloaded correctly there should be no contact with the plunger to the retainer, that holds the plunger in the lifter, when there is no load on the plunger sorry if that sounds wierd!!Therefor there should be no stress on that clip to break,Thanks for your guys opinions and suggestions
Old Jan 11, 2006 | 07:10 AM
SAM98WS6's Avatar
measure your preload with a dial indicator...not just turns....good luck
Old Jan 11, 2006 | 08:41 AM
FRDnemesis's Avatar
I have run these for 30k miles in my LT1 car with 1.6RR Comp Magnum rockers, Comp pushrods, Comp springs, and the Comp Cam 306. I have never had any issues with them. As a matter of fact, those are the only lifters that my engine builder uses.
So I bought a set for my LS1 car last year and I was planning on putting them in with my Comp Cam this month. But now after reading some of this, I am not so sure. With the talk of Aluminum Block expansion rates vs cast iron, and quality control, I'm pretty weary.
How much are the Morel's and who sells them?
Jeff
Old Jan 11, 2006 | 05:39 PM
Viper's Avatar
Morels are roughly $500. PM me for a source.
Old Jan 11, 2006 | 06:35 PM
JRracing's Avatar
Jeff
I'm with ya on this issue. I don't want to be a band wagon jumper but I will not take a chance like that on a set of lifters I paid 150.00 for.
I have a NIB set of comp "R"s 850-16's I got off of a guy on here. They might have to hit the market.
Old Jan 11, 2006 | 06:47 PM
JZ'sTA's Avatar
Originally Posted by SAM98WS6
You know..I used these parts without issue...but if I was doing it again I would use something else and not risk it...obviously making these exact valvetrain components work properly is not easy.
I would use Morels and jesel if I had the money and wouldnt use stock if they were the last parts on earth.
Thats funny because if you post a new thread saying who uses stock lifters and what kind of results have you had I guantree the feedback is more positive then the feedback in this thread.
Stock lifters 99% of the time work great. There are 100's of combo's using bigger cams like the T rex/G5X3/ G5X4/G5X2/Juggernaut/ etc that use stock lifters with no problem.
I myself have done over 25 H/C installs this past year alone with not 1 single lifter problem. But your right stock lifters suck.
Old Jan 11, 2006 | 06:59 PM
Redneck Z's Avatar
I don't see why most couldn't just use the COMP stock replacement lifters and not have to sweat the R's. I wouldn't touch the R's, with all the horror stories and extra $$. I don't see how it's worth it.
Old Jan 11, 2006 | 11:19 PM
Phil99vette's Avatar
7 Second Club
<== ran comp Rs in the old setup and worked great, no issues what so ever.
Phil
Old Jan 12, 2006 | 06:52 AM
DAPSUPRSLO's Avatar
Yes, the point of all of this seems to be that the much more pain in the *** of the R lifters (rediculous pre-load range of only .002-.004), even without suggesting the possibility of a faulty piece, is just not necessary as the stock lifters are putting up with some big rpm and some very agressive hydraulic lobes.
Old Jan 12, 2006 | 11:22 AM
  #32
SAM98WS6's Avatar
Sorry I was referring to stock rockers but if you are building a $8,000-10,000 motor or more and 600+hp...why would you not use Morels and Jesels for example..or Comp Rs and Pro Magnums..more HP and reliability. Everyone is different I guess. Critical Stock pieces werent even a consideration..I work too hard for my money...if im doing something its done right.
Id use stock lifters if I was doing a cheap rebuild and my cam wasnt too wild.
