fm13 or fm11
Old Jan 10, 2006 | 02:00 AM
TXZ28LS1's Avatar
Default fm13 or fm11
which of these cam specs will be better suited for a daily driver in an auto. the stall i will be looking at is a 3200 stall. which pulls harder than the other throughout the rpm range..thanks
Old Jan 10, 2006 | 07:36 AM
Kraest's Avatar
The F-13 is a tried and true performer. I'd go with a bigger stall than that on a stock motor, though.
Mike
Old Jan 10, 2006 | 09:12 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I've seen very stout F11 setups that rival F13 #'s. It's relative to your overall setup.
You're fine with either one.
Old Jan 10, 2006 | 10:09 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I went with the F13 and a TCI 3000 stall. I talked to Allen and asked him if the converter was too low for the cam and he said NO it will work great. Just my .02
Old Jan 10, 2006 | 04:34 PM
TXZ28LS1's Avatar
thanks..i want to run a vig. 3200 and from what i hear its really a 3600 or something like that. i just want a nice cam thats a lil rought than a 224 cam. im seeing good things from the f11/13 cam too. im looking into maybe some afr with it at the same time. i wonder which will make more usable hp for the streets than track.
Old Jan 10, 2006 | 05:00 PM
WickedC5's Avatar
That's exactly what im trying to figure out between the two. i need the power under the curve. what LSA are you thinking of running in your A4.
Old Jan 10, 2006 | 06:28 PM
00byrd's Avatar
I have the F11 been in the car for 19 mths. and I love it.
Old Jan 10, 2006 | 07:02 PM
krexken's Avatar
Check out some of the graphs in dyno section. Quite a few in there with these cams. Those F11s seem to have a really nice torque spread.
Old Jan 10, 2006 | 07:07 PM
Brandon Boomhauer's Avatar
The F11 makes a really nice broad powerband, I'd say the F13 is a little more peaky though.
Old Jan 11, 2006 | 08:44 AM
LS1 BU's Avatar
I would run the f11 with that stall.
Old Jan 11, 2006 | 09:54 AM
TXZ28LS1's Avatar
yeah, the f11 looks good. plus i didnt want to go too big of a cam. what do you think my # would be with afr 205 with the f11 longtubes, pulley, stall, ls6 intake, pulley, and catback?
Old Jan 11, 2006 | 10:01 AM
PREDATOR-Z's Avatar
Properly done with attention to details 430>440rwhp
