CNC Ported 243 Budget Heads $865.00 Per Pair, Assembled
Old 01-19-2006, 09:22 AM
Gunnar@Patriot's Avatar
Originally Posted by 01350ss
Would the $865 heads work with thunder's t-rex cam?
No, unless you already have the springs to go with your cam, you will the heads equipped with the Patriot Gold springs which would be $1,125.00 with new GM MLS head gaskets, new OEM head bolts, and shipping anywhere in the US.
Old 01-20-2006, 05:52 PM
01350ss's Avatar
ok but aside from the springs the heads would clear the cam rates?
Old 01-21-2006, 07:13 AM
PREDATOR-Z's Avatar
Unmilled with stock valves, YES
Old 01-21-2006, 01:17 PM
bullygoat's Avatar
So do these heads flow better than the 2029 heads?
Tim
Old 01-23-2006, 10:48 AM
Our 243 castings and our LS6 style heads will have comparable flow. These heads are an excellent value. All of our head are built using the highest quailty parts available: Ferrera valves, the Orginal Patriot Gold spring, Ti tanium retainers, Bronze guides, Machined Super 7 locks, Viton seals, ans Machined Spring Bases.
