Which solid lifter in place of hyd to check pushrod length?
Old Jan 12, 2006 | 07:03 PM
RSB's Avatar
RSB
Default Which solid lifter in place of hyd to check pushrod length?
1. Am I correct that a solid lifter vs. hydraulic must be used to check valvetrain geometry?
2. How does a person know which solid lifter mimics the operating condition (pumped up) of a particular hydraulic lifter for testing purposes?
The lifters in question are 2000 LS1 roller.
Thanks
Old Jan 12, 2006 | 07:39 PM
vettenuts's Avatar
I am going to use my hydraulics with checking springs since the Morels are a little taller than stock. Rather than magic marker, white out comes off fairly easy with a light load on the rocker so the swipe test should work OK. Haven't done it yet though.
Old Jan 12, 2006 | 08:25 PM
Bink's Avatar
I bought a new/replacement stock lifter. Took it apart, drained it and then filled the chamber completely with high density, self curing acrylic - then I reassembled (spring pushes seat into place) and let excess vent through the seat/cup -> Solid mock-up at max. pump. It worked very well with comp 918s.
As I turned her over I did have a transient image of the lifter shattering in the bore and acrylic everywhere.
Old Jan 12, 2006 | 08:47 PM
Grimes's Avatar
jb weld> all
