Rocker arm bolt tightening proceedure?
How important is it to follow the bolt tightening proceedure for the rocker arm bolts. Some head swap write ups don't discuss it @ all & the shop manuals seem to think it is imprtant.
Here's what I'm referring to: #1 piston TDC then tighten intake rocker arm bolts 1,3,4,5 & exhaust bolts 1,2,7,8. Rotate 360 deg. then tighten the remaining rocker arm bolts. Why? What does this ensure? Thank-you.
I do TDC with both valve closed and I follow firing sequence, that's 1 & 6, rotate 90, 8 & 5, rotate 90, 7 & 4, rotate 90, 3 & 2.
Now you have done a complete 360, rotate 2 full more revolutions and check trq one more time 22>24ftlbs
