Question about swapping LQ9 heads and compression.
Old Jan 15, 2006 | 06:04 PM
Raced Guy's Avatar
Default Question about swapping LQ9 heads and compression.
I was told if you swap LQ9 heads onto an ls1 you will lower the compression by about 1 point, is this true. And if it is, is everything as far as the valvetrain and what not the same ???
Old Jan 15, 2006 | 06:08 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Valvetrain is the same. It may drop it one point, but depends on gaskets as well.
Old Jan 15, 2006 | 06:12 PM
Raced Guy's Avatar
Well basically im looking for a way to lower compression some because im going turbo and dont want to tear into the bottom end right now. Just want to lower it a little for saftey sakes. So can i just change out the head gasket to lower compression, i know you can to raise it.
Old Jan 15, 2006 | 06:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
yeah it works both ways...I am not an expert on which gaskets will +/- compression. I just know that is how some people move it around. But yeah, when you said that you were going with the LQ9 heads i knew you were looking to drop your CR.
Old Jan 15, 2006 | 06:28 PM
Raced Guy's Avatar
Yeah then i will fell alot safer about running the boost i want to run.
Old Jan 15, 2006 | 06:54 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What ideal CR are you looking for? 9.1, 8.5?
Old Jan 15, 2006 | 07:04 PM
Raced Guy's Avatar
If i can get it in the low 9's i would be happy, id be very happy with 8.8-8.9 to 1.
Old Jan 16, 2006 | 03:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
yeah that would be ideal I would think for some major forced induction.
Old Jan 16, 2006 | 04:31 PM
Raced Guy's Avatar
Old Jan 17, 2006 | 05:44 PM
Raced Guy's Avatar
So can anyone verify if these heads will lower compression???
Old Jan 17, 2006 | 06:42 PM
JZ'sTA's Avatar
Compression with a typical LS1 bottomend and a .054 gasket with non milled LQ9's will be right around 9.5:1
