How big a cam w/ 918's
Old Jan 17, 2006 | 01:19 PM
SideStep's Avatar
Originally Posted by Greg_E
I would say that depends on what lobes you have on that cam. Comp does not recommend the 918's if your using the XER lobes.
I don't know if people are using the 918's with the XER lobes with success, but would like to know, seeing as I am installing the 224/224 .581/.581 114 XER and the heads currently have the 918's installed.
I was on the phone with tech-support (CompCams) yesterday and they recommended the 918s for .600 lift XE-R type cams....
Old Jan 17, 2006 | 04:00 PM
hc_performance's Avatar
Sorry to hijack your thread but I have the 918's, and they are not the blue striped ones like on comps web site. These have the white stripe. Do you guys think that they are just as good as blue striped ones?? I have the f13 in the vette and I don't want to take a chance on dropping a valve!!!
Old Jan 17, 2006 | 04:03 PM
baddogz28's Avatar
I have been running 918's with no problems (TSP 233/239, 598/603)
Old Jan 17, 2006 | 04:09 PM
marine02ss's Avatar
D-money's friend thats going to install that cam is my friend as well,we decided to switch over to patroit golds.Just wondering PTV clearance should be ok with that cam,228/232 585/595 114?
Old Jan 17, 2006 | 04:32 PM
Dmoney's Avatar
I knew I forgot to ask about that.
Old Jan 17, 2006 | 07:32 PM
Greg_E's Avatar
Originally Posted by PREDATOR-Z
Really???
That is ammazing, because that is exactly what they recommend and 921's as an upgrade.
I've personaly run .610 lift on 918's with no issues, quite the contrary, more power, when I swapped the stock valves/duals for LS6 valves/ 918's on the same head,
11 rwhp extra on the same day.
I stand corrected. I swear I read on one of the Comp online catalog pages a while back, that the dual springs were recommended for the XE-R lobes. I searched for that page and can't find it. I did find the page that said 918's were OK to use with the XE-R lobes. Maybe it was one of the vendor sites where I read it, but I didn't make it up.
In any case, that's a good thing for me. I won't have to swap out the new 918's and Ti retainers that I have on the heads I'm installing. Thanks for calling me on that one. You just saved me at least $300.
Old Jan 17, 2006 | 07:51 PM
MattIROC's Avatar
918's also 232/234 .595/.598 Comp XER281HR cam.
Old Jan 17, 2006 | 08:25 PM
71camaro's Avatar
Im running this with absolutely zero problems. (knock on wood)
Old Jan 17, 2006 | 10:11 PM
racecar's Avatar
918's shimmed .050 on a TSP 233/239 .598 .603. Pulls strong to 6600
Old Jan 18, 2006 | 06:32 AM
2001 Pewter WS6's Avatar
Restricted User
Interesting... I have a Comp XE-R 244/248 and the rep said I needed Comp 977's and Comp R lifters. Well I developed an intermittent tick and think it is the lifters. I would love to go back to a stock style lifter and 918's if they would work. I am just worried about having enough spring pressure.
Old Jan 18, 2006 | 07:21 AM
SideStep's Avatar
