5.3 heads???
Old Jan 17, 2006 | 07:47 PM
silverlt1ss's Avatar
Default 5.3 heads???
i have a set of stock 5.3 heads from a 02 yukon. i was wondering if they are better than a stock ls1 head??
Old Jan 17, 2006 | 08:03 PM
ssheets's Avatar
They're the same design with smaller intake valves and the combustion chamber is cast at .030" lower for a 61.3cc chanber vs. 66.67 on the 5.7 heads. So a direct swap will bump your compression aup to around 10.9ish, but will reduce your flow....not a great return on the labor investment. However, worked 5.3 heads with bigger valves can be a great combo.
Old Jan 17, 2006 | 09:01 PM
black01_WS6's Avatar
ship the heads out and get them worked and then they will be worth the swap.
Old Jan 17, 2006 | 09:11 PM
thanks
