12 pt Head studs torque specs
Old Jan 18, 2006 | 01:50 PM
Camaro_Zach's Avatar
Default 12 pt Head studs torque specs
since the search seems to be broken, im posting this. does anyone have the torque specs handy
Old Jan 18, 2006 | 02:28 PM
Nate_Taufer's Avatar
70 ft lbs for the 1-10 bolts and I think 15 ft lbs for the bolts that go under the manifold (it's either 12 or 15 ft lbs).
Nate
Old Jan 18, 2006 | 02:44 PM
Black Z/28's Avatar
My ARP instructions said 70 ft lbs if you are using ARP moly lube (which is what I used). I did it in 3 passes, 50, 60, 70. Top row goes to 22 ft lbs.
Old Jan 18, 2006 | 02:51 PM
thanks guys! thats all i needed!
for the records too, ARP calls for 63-65 when using an aluminum block, 70 with the iron, i remembered that, just not the specs for the small studs.
thanks again!
Old Jan 18, 2006 | 02:58 PM
Black Z/28's Avatar
thanks again!
Damn, you're right. How did I miss that? I just checked my instructions- 65ft lbs for aluminum. I'm over torqued!
Old Jan 18, 2006 | 03:01 PM
JMBLOWNWS6's Avatar
I put mine to 75. On a LS6 block.
Old Jan 18, 2006 | 03:12 PM
JMBLOWNWS6 - not sure as to the ramifications to that, but you probably shouldnt have them that tight, thats more than they call for on the iron block.
Old Jan 18, 2006 | 05:38 PM
2scoot's Avatar
We do ours at 65 in one pass and then recheck when complete.
I know what ARP calls for but all the lube is gone by the second round.
Perfect torque on the first pass!
