View Poll Results: Should I make the switch to Royal Purple?
Yes
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
137
39.60%
No
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
209
60.40%
Voters: 346. You may not vote on this poll
Mobil 1 or switch to Royal Purple?
#43
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by TroubledWine3
Hey, you are the one that brought him up, buddy, not me LOL.
My reasoning for this was to help the original poster gain information for himself so that he can form his own opinions with solid information. Not neccessarily to just run out and grab whatever is recommended in this thread or that.
#44
Originally Posted by Cheatin' Chad
I don't care who recommends Mobil1 at this point. EVERY single motor that I have had apart that uses it has varnish all over it. I just do not see this with other high end oils.
Personally I use Redline and it consistently outperforms the other oils I have used. Is it better than EVERY other oil? I don't know I haven't used them all. All I know is from the oil analysis I have had done Mobil1 in the 10w30 and 10w40 grades I use is not as good as Redline or Amsoil.
understandable since it does leave a yellowish tint on everything.
if you do some research on moly coating and synthetic oil, you'll find some interesting info. i wont bother trying to describe it myself, since i cant describe nearly as good as others. my English is the suck this morning.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#45
11 & 7 Second Clubs
I always put oil in my 622 race motor filter before installing, but have never done it on my LS1, although it makes sense to.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by Grimes
no, it's definitely a good idea. pressure builds much quicker with the 3/4 quart in the filter already!
#46
11 & 7 Second Clubs
I wonder what his reason was for recommending 0W-40 over 10 or 5W?
Patman reccommends Mobil 1 0W-40 right behind German Castrol.
I switched from 5W-30 dino old to 0W-40 Mobil 1 at 97k miles when I did the ported LS6 oil pump and it did wonders for my car. Definitely not going back now. Love that stuff.
#48
I'm not a big fan of Mobil 1 oils though, but I know there are a lot of people on here who will run nothing but Mobil 1, so I had to give them some sort of better choice than their super thin 5w30 (which is almost a 5w20)
#49
#50
11 & 7 Second Clubs
I am again reminded of the complexities of the "which oil to use" question, which is determined by various factors such as, is one trying to make the most power or to maximize engine life. The answers to such quetions will determine which oil to use. Thinner oils will make more power, but reduce engine life. The inverse is true for heavier oils.
#51
that is SOOOOO not true.
think about this:
we can all agree that the most engine wear occurs at startup, when the engine does not have the full VOLUME of fluid running thru it yet.
a thinner oil pumps quicker and can get into the bearings sooner.
a thicker oil will show PRESSURE sooner, but takes longer to pump around the motor.
sitting overnight, they both will have runoff.
if they're synthetic, both should also leave a rather good film on the parts anyway... so the amount of oil remaining is almost identical.. just because its thicker does NOT mean more oil will stay on there....
in most real life situations, it turns out that the quality synthetic thinner weight oil actually protects better then the thicker oil... even though it reads a lower pressure at times.
#52
11 & 7 Second Clubs
MrDude,
We have dyno'd our engines, such as our 622, and tested everything from 10W30 to RP racing lite, and there a 20 hp range between these oils. So, it really is sooooooo true that lighter oils make more power.
#53
MrDude,
if you read what i wrote and not just the first part, you would see that i never disagreed with that.
#54
Only ran 10w 30 Rp in my ls1 since I have had it....had a 91 mr2-t only ran Rp once I got it.....never had any problems with either....never had oil loss/burning issues, only possitive results....and strong running engines. Just my personal experience.....Mobil 1 is junk, just cause everyone hypes it, and they spend alot of $$$ of advertising doesn't make it the best. Never tryed the german castrol...but have only heard good things aswell. THanks
#55
so basically what you just said is..... i have XYZ and it kicks ***. i have not used product ABC, i have no results for product ABC, but ABC sucks because i like XYZ sooo much.
is that correct?
[sarcasm]
its good to know people that use such sound logic give tech advice.
[/sarcasm]
#56
Patman, I think others have asked about this, but anyway, have you seen any comparos between the new Cosworth oils and the usual "standards" (i.e.; GC, various Amsoils, Redline, etc.)??
#57
#59
Originally Posted by GTOTitoLS1
mobil 1 is good , but it all depends on what you have. I personaly don't like it, GM only recommends mobil 1 on vette LS1, not all LS1, there is a slight difference in vette LS1 and camaro and tran Ls1, stock Ls1 on camaro was only 325hp versus LS1 on vette stock output 350h, anyways the oil pump on vette LS1 is different , suction screen changes, but like I said mobil 1 is still pretty good for any motor, in some camaros , mobil 1 produces a ticking sound , and GM does not recommend mobil 1 on 2004 GTO LS1 that has 350hp, I personaly like Q oil 5w30 and in summer I use Q 10w30 , Mobil 1 was turning dark to fast after I made it twin turbo. But that's my oppinion.
Where do you come up with this BS? Can you keep your posts in the lounge section only?
I think this deserves one more look.
Back on topic.......I've ran nothing but Mobil 1 5w30. Everything looked great at 100,000 miles.
#60
Originally Posted by Anthony Williams
Have you ever tried to buy Royal Purple on a Sunday or a Holiday, Wal Mart sells Mobil 1 in a nice 5 and 1 Qt bottles.My point being if your racing on sunday and need more oil-well I know wal mart is everywhere and open ! and if Mobil 1 is good enough for everything from Vetts to Raptor F-22's that is it's good enough for me.
As a quick side note turbine engines do not use oil for the same lubrication purposes that car or other reciprocating engines do. If you were to use the Mobil oil that turbine engines use you would find that shortly after using it not much would be left of your engine.
