How to pre-oil?
Old Jan 18, 2006 | 05:26 PM
RSB's Avatar
RSB
Default How to pre-oil?
So how does a person build oil pressure in gerorotor equipped engines?
Old Jan 18, 2006 | 05:31 PM
BLKWS6's Avatar
unhook the coil packs and turn the motor over till the oil pressure jumps up to normal level. easiest way. Just make sure you turn it over for about 10-15 secs at a time.
Old Jan 19, 2006 | 01:31 AM
PREDATOR-Z's Avatar
Also take fuel pump fuse out.
Old Jan 19, 2006 | 06:31 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
no spark plugs either
Old Jan 19, 2006 | 06:46 AM
02WS6Bird's Avatar
The way it sounds to me is that you guys are saying to almost start the cat, just w/o spark and fuel so bascillay just Cranking the motor via the starter?
Old Jan 19, 2006 | 07:35 AM
oange ss's Avatar
yes, it's better than runnin the motor till pressure builds
Old Jan 19, 2006 | 07:58 PM
67Ranger's Avatar
i used a thing that the shop that had built my engine built up. It was basically a small freon bottle, that had a cap on the top that you could hook up an air hose to. Then there was a hose that came out, and we made an adapter to go into where the oil pressure sending unit goes. Then pumped a couple quarts through it. The other way is probably easier though.
