How to lower compression on stock ls1 ?
Old Jan 18, 2006 | 05:26 PM
Raced Guy's Avatar
Default How to lower compression on stock ls1 ?
I want to lower my compression a little because im going to boost,. I was told if you swap lq9 heads on it will lower it. Is there any other ways you can besides getting into the bottom end, maybe different head gaskets ???
Old Jan 18, 2006 | 05:31 PM
Starz T/A 17's Avatar
A thicker head gasket will change the compression but not sure how much
Old Jan 18, 2006 | 05:47 PM
Raced Guy's Avatar
Can anyone help me out with what thickness i should get. Ig going with the 6.0 lq9 heads, i was told 54mm will bring it to about 9.2-9.4 to 1.
Old Jan 19, 2006 | 10:04 AM
VSGLS1's Avatar
Search in here, there was a Sticky with head CC's vs compression. Also there are compression calculators to help with the info you need.
Old Jan 19, 2006 | 10:47 AM
00BlackSS's Avatar
6.0L heads from a GM truck will lower ur CR
2002 LQ9 Aluminum found on 2002+ 6.0L High Performance trucks will make the compression ratio about 9:1...this head is alsmost the same as a LS6 head with imporved intake and exhasut ports
2001+ LQ4 Aluminum found on 2001+ Low Performace tucks with 6.0L will also make compression ratio about 9:1
Old Jan 19, 2006 | 10:54 AM
GuitsBoy's Avatar
Every .005" thicker head gasket you use, the combustion chamber volume increases 1cc.
Old Jan 19, 2006 | 11:45 AM
white2001s10's Avatar
thicker headgaskets is the worst way to lower compression IMO because of the effect on the squish/quench area.
I would consider unshrouding and polishing in the chamber before anything else.
Old Jan 31, 2006 | 12:34 AM
kjmdrumz3's Avatar
I would buy the 6L heads, and have some headwork done to those. Run stock gaskets and call it a day. I was going to do exactly that but I'm going iron 370 real soon and a set of after market castings.
Old Jan 31, 2006 | 12:51 AM
NoGamesLS1's Avatar
http://www.diamondracing.net/cocalc.htm
Old Jan 31, 2006 | 02:37 AM
ChaseSS's Avatar
i dunno if you want to do it but since your lowering the CR i imagine you are going to be wanting to make some serious HP so might want to even consider a forged bottem end.
Old Jan 31, 2006 | 03:54 AM
bluecamaroz28's Avatar
Limit on stock bottom end is about 10# of boost and you can make that with stock CR, intercooler, good tune and water/meth injection on 93 octane pump gas.
Post it in FI forum for more feedback.
