Bent and Broken Pushrods... NEED HELP!!!
Old Jan 31, 2006 | 02:51 AM
  #41
DarknessC5's Avatar
I just don't know what the hell to do now....
Old Jan 31, 2006 | 03:17 AM
  #42
DaddySS's Avatar
Simple - if you want to be certain - pull the heads and the oil pan. If you want to see if you can skate, pull the pan down a bit, fish out the pushrods, put in hardened rods and see what it sounds like.
Old Feb 1, 2006 | 08:53 PM
  #43
DarknessC5's Avatar
Default Update
Tried the pen magnet and got the rest of the pieces out....
Maybe I can get away with some hardened pushrods and some new rocker arm bolts.
Is there anyway to check the timing chain without pulling the cover?
Old Feb 1, 2006 | 10:10 PM
  #44
aux_fast_cam's Avatar
I would get some hardened pushrods. You are going to need them no matter what you do. Then install the pushrods roll the motor over by hand with socket on crank and plugs out of motor. Watch for the valve events, change the oil, and if all looks good try to fire it up. This won't damage any thing that is not already damaged. If it runs ok leave it alone, if you notice something when you fire it up shut it down.
Old Feb 4, 2006 | 07:37 PM
  #45
DarknessC5's Avatar
Well I picked up the hardened pushrods... And I am going to do what is posted above... Hopefully I will get lucky and everything will check out ok...
Old Feb 6, 2006 | 12:25 AM
  #46
alsfastz28's Avatar
magnet on oil plug may have some shavings on it try that to see any metal also check piston valve clearence just to be sure good luk man!
Old Feb 9, 2006 | 09:51 PM
  #47
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So what happened?
Old Feb 12, 2006 | 11:45 PM
  #48
CamTom12's Avatar
Originally Posted by vettenuts
Why would the valves hit his pistons? The stock pushrods are weak, every LS1 book out there states that. You effectively almost doubled you column loading on the pushrods and they buckled. No surprise there. See if you can find the rest of the pushrods that are broke. Do you have access to a boroscope? That would aid in finding the broken pieces and you can also inspect your pistons.
I am not familiar with the f-body setup, but the Vette has "camel mode" that the engine goes into if the engine temp goes too high. They alternate the pistons that are firing so you can limp home without damaging the motor. Not sure if the f-body has this feature. I wouldn't panic yet, sounds like you did the right thing in parking it. Although I would be willing to bet you "goosed" if a few times with the headers open.
F-body's have that mode. I stumbled across it this summer idling in the Alabama heat with the AC on... Sounded almost like a stutter-box set to idle.
Old Mar 7, 2006 | 07:36 AM
  #49
MaxxMitchell's Avatar
WOW what a story, any updates?
Old Mar 22, 2006 | 02:19 AM
  #50
DarknessC5's Avatar
Changed the pushrods and the car ran fine... Then I sold it to buy a house...
