View Poll Results: What's the best "Street" Cam Lobe?
FMS/Cammotion
49
24.50%
Crane Cams
14
7.00%
Comp Cams
137
68.50%
Voters: 200. You may not vote on this poll
Poll: What is the best "Street" Cam Lobe?
Based on the original question, about wanting something easy on the springs and valve train as a pricipal criterion, why not just keep the Crane?
On the measurement, something I have been confused about. David Vizard discusses that the standard for duration is 0.004 at the lifter, but with the standard small block 1.5 rocker, some cam manufacturers use 0.006 at the valve as their standard. Is this the difference from Crane to Comp, which would mean they are basically the same? I know Crane uses 0.004 at the lifter.
I'm running A Futral cam and i've had 0 problems. I'm Smog legal for Cali 224-228 on a 114 LSA (translated -i felt safe @ the stop lights)
I could have gone longer duration but i'm trying to pass for stock.
Hawk
Hawk
LS1 Tech Administrator
With a 5.3L truck, you want a fairly early intake valve close to allow peak hp under 6000 rpm and massive torque down in the mid-range. You'll also want a fairly narrow LSA to keep an early IVC without having to advancing your cam too much. I'm a big fan of the faster ramped Comp lobes (XE-R or LSK lobes anyone?). With a good dual spring shimmed to within .050" of coil bind (to eliminate spring surge and promote longer life), there's no reason you can't get 30-40K miles out of a set.
With ported heads like the Patriots, I'd probably go something like this:
215/227 .629/.639 110LSA +2 advance.
This gives an intake valve closing point of 35.5 degrees ABDC. This will make for strong power under the curve in a 5.3L and will make peak power under 6000 rpm. Just the ticket for long life in a heavy vehicle running an automatic.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#32
14 Second Truck Club
#33
advertised duration numbers are just that: advertised. They can pretty much measure them however they want to and make the cam look however they want. Try not to put too much stock in them, and don't use them in calculations and expect it to be the "final answer". There's a reason the standard is @.050...
#34
WoW!
spring life is in the 20000 to 40000 miles with some cams and double springs!
I thought just choose springs that matches the cam and you can drive +100000 miles just like a stock cam and springs?
My plans are some ported heads (probably Patriot stage II ls6) with their springs and a cheatr cam or something close to it (stock idle sound and 1200 - 1500 rpm cruising without shaking or rattling) so can`t I use a cam with patriot springs or the comp behive ones and drive without worrying for say 60 k miles?
#35
Originally Posted by 99silveradoSS
Thanks for the info, but the cam I pick will be going in a stroker (382 LS1). I'll probably go with the cam TR recommended(224/228-.58x/.59x-110lsa), it's an XER lobe. How do you think that would do in a 382 LS1? Thanks.
231/235 .643/.646 110LSA +1
If you wanted, you could always substitute an XE-R lobe for the exhaust.
#36
What's the benefit of substituting an XE-R lobe for the exhaust? Would the 231/235 cam be like instant torque off idle? WHat do you think that would peak at and be capable of producing hp/tq wise with headers and stage 2 pp 5.3 heads? Thanks for the help!
#37
The 231/235 110LSA LSK cam is more of an all-around power-grind. Even with your power-robbing truck driveline, it should make 400+ rwhp through an unlocked converter. If you're looking for more instant power off idle, then you can make the intake duration a little smaller:
224/235 .633/.639 110LSA +2 ground with Comp LSK lobes.
This would rock in a 382 truck with instant torque off idle.
Probably 400 rwhp at 5700 rpm, 440 rwtq at 4400. These are automatic numbers remember.
__________________
#38
Some people like running an XE-R lobe instead of an LSK lobe because the exhaust needs to be really quick off the seat to build best torque and they will sacrifice some lift to get a little quicker valve action at .006". I still like the greater area under the curve with the LSK lobes.
#39
That's what numbers I would like to see on the dyno, my goal was ~400rwhp/425rwtq. The 231/235 cam should produce more than enough low-end with say a 2600 converter, right?
#40
UNDER PRESSURE MOD
I just pulled up my cam card from my TR224 cam from 3.5 years ago.
According to the calculation above, I have 51 degrees between the 0.006 lift and my 0.050 lift, so I guess it's on the agressive side of the equation. Back in 2003 the car dyno'd 430/400 with mac headers and a shitty 2.5" ypipe that had numerous crushes in it.
Now with QTP longtubes and ypipe, I wonder where I'm at power wise and if a cam change would net me much. I still have a stock pulley and ls6 intake, so I bet that would net me a few extra ponies.
I learn something new every day on this site.
Thanks guys.
Thanks guys.
