Amsoil 20-50w ?
Old Jan 20, 2006 | 01:26 AM
chpmnsws6's Avatar
Default Amsoil 20-50w ?
would it help or harm a fairly built ls1 to run 20-50w? with 10-30, it sat around 40psi at idle and 60-65 psi when playing.
what are the benefits/downfalls?
Old Jan 20, 2006 | 05:09 AM
Patman's Avatar
There is no need to run such a thick oil, you're just robbing yourself of horsepower and possibly will end up with higher oil temps since the engine has to work harder to push through that thicker oil. I would not go any thicker than 10w40.
Old Jan 20, 2006 | 12:31 PM
chpmnsws6's Avatar
why do all the higher hp cars run it? keep in mind, the ring gap will be .028 or greater for spray.
i can get the lighter stuff, just didn't know why people seem to push this weight
Old Jan 20, 2006 | 09:58 PM
ss1's Avatar
ss1
I run Amsoil 20w-50 in my racecar engine and have always had good luck with it. So in my LS1 I first tried Amsoil 10w-40, but had quite a bit of valvetrain noise. I did quite a bit of research on why I shouldn't use 20w-50, but figured i'd try it anyway. My next oil change I went with the Amsoil series 2000 20w-50 and it quieted it down a little after the engine warmed up as compared to the Amsoil 10w-40. The reason I don't have a problem with the 20w-50 Amsoil is, it's thinner than conventional 10w-40 (which is what some run in their engines) when the engine is cold. Supposedly, after the engine is warmed up the Amsoil won't lose a lot of its viscosity. Just my opinion, you know how that goes. I'm not an oil expert, but have used many different oils and have had varied results.
Old Jan 21, 2006 | 12:28 AM
Okie5.3's Avatar
I wouldn't run it in a DD, especially now that it's winter. Lost a main bearing once running 20w-50 when a cold snap snuck up on me.
Old Jan 21, 2006 | 01:10 AM
chpmnsws6's Avatar
talked to the boys at the shop. they said it was for loose tolerance race motors. the 20-50 holds to parts while going around corners so the parts don't get oil starved nearly as quick
