Maximum Overlap on F-Body Stock Manifolds
LS1 Tech Administrator
Originally Posted by PREDATOR-Z
Patrick,
If you remember in my previous thread you were pushing 42 IVC, with the reason that I will be missing 10 rwhp if i didn't use that.
Yet here, you recommend a 38 IVC.
What is your philosophy behind this? Is it because you are choosing XE-R over XE lobes?
I'm just trying to understand your logic.
But in Ragtop's situation, he specifically detailed that he wanted a 6000 rpm shift point. Knowing that, he'll need his peak power to occur at 5800 rpm. To accomplish that, he'll need an IVC of 38 degrees. While Joel will be leaving quite a bit of power on the table above 5500 rpm, this clearly doesn't seem to be of concern, hence the recommendation for the earlier intake valve closing point.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
Typically, I recommend a 44-46 degree IVC for best power under the curve in a 346, but to do that makes the power peak at 6300, which is higher than some people like to twist their motors. For a true daily-driven A4 or M6 that wants a little more low end torque, I'll back it up to 42 degrees (like you mentioned).
I thought I was going bananas, but I stuck to my decision. ( But I was doubting my understanding)
Anycase all is well, the cam is ground and I'm awaiting $$$ for heads.
For a car that needs good top end, IVC = 42* is the minimum I'd do. I'd also look for and EVO in the high 40s or or more unless the exhaust is really free flowing. I need the car to slice through traffic with fast throttle response at low rpm so I'm trading off the above 5500 rpm power.
When I was an A4, I did the opposite. I had a big stall and went for an IVC = 48 and made goobs of power up top. Since I never went over 1/3 throttle below 4000 rpm, I didn't care about low end torque.
I was looking at an IVC = 40 until I started looking at the stock F-Body cams and thought more about DAB's 224/224 110 106 which also used a 38* IVC.
When I put my cam specs together I looked at 3 cam types.
Vinci /Crane (low trq >38* IVC)
GM LS6 (compatibility with stock exhaust- Large intake/exht split-emissions)
CheaTR cam (power made and EVO)
So this cam was born.
Pontiacerator
I really like the CheaTR/Old Man 215 .600 lift lobe. I'd recommend using that if you can. I'd also recommend an XE-R exhaust lobe for really good idle and better low end torque. A 38 IVC is probably what you're looking for. That said, here's something you might like: 215/224 .600/.581 114LSA, 110ICL
Originally Posted by RevGTO
Patrick, Ragtop, et al., do you think this OMC/XE-R lobe combo would bring a lot more to the table than a 214/224 XE on a 110 or 111 ICL? Maximum valvetrain reliability is a concern, but also, the best power under the curve. Also, do y'all agree that keeping rpms at 6000 & below is important for A4 longevity? All this plays into cam selection for a DD.
The OMC/XE-R lobe combo is probably about the most hell-for-stout combination you can run for a pure street car, but keep in mind, the ramps are pretty aggressive. Proper spring choice and setup is key to ensuring long life. For best power under the curve, I highly recommend LSK lobes first, then OMC lobes, then XE-R lobes. For longer spring life and less valvetrain noise, the Comp XE lobes along with the Crane lobes are very nice. Cams are all about compromise. The 215 OMC lobe just happens to be around the best balance of power, driveability and longevity that I've found.
I would not recommend a 110 or 111 LSA for a motor running stock exhaust manifolds because it would either have too much overlap (causing nasty reversion) or the duration would be too small to keep the overlap in check. As outlined in post #1 and #2, you want to limit overlap at .050" to -5 degrees if possible. -10 is better in fact.
__________________
Pontiacerator
How much longer spring life/less power would the XE lobes give you vs. the OMC/XE-R combo assuming similar specs?
Rev:
There's a pretty big difference between the OMC lobe and an XE. Maybe Patrick has the difference in total lobe area from a cam doctor report. The XE-R compared to the XE gives you more than just lift. It is faster off the seat, so you get more duration all through the lobe for a given amount of total overlap. Reducing the total overlap can improve idle and low throttle driving Here's an example holding total duration constant:
..........total
Lobe...duration...05....200
XE......277.......224....142
XER....277.......228.....149
As you can see, there is a nice pickup starting at .05, 5% more duration at .200, and by .300 there is a much more pronounced increase on a percentage basis.
BTW, with your 3000 stall, you can use an IVC a little later than what I'm looking at and have good performance. the 214/224 114 straight up or 1* advance should get you off the line and preserve your top end a little more.
..........total
#32
Here's another comparison. Look at the duration at .200", then look at the total duration (at .006):
..........total
OMC...265.......215....142
XER....269.......220....143
XE......277......224.....142
So as you can see, the Thunder Racing 215 OMC lobe has as much duration at .200" lift as a Comp XE lobe with 224 duration. This is one of the reasons why the CheaTR cam and Old Man Cams make so much power. Lots of area under the curve with very little advertised duration.
..........total
__________________
#33
Pontiacerator
I realize that the steeper ramp rates of the OMC and XE-R mean more than just higher maximum lift - and that means more potential power per valve event than a lazier lobe of the same duration. But again, I'm balancing that positive against the potential negative effect on spring life. Running duals would address that problem, but I'd prefer to run 918's for a number of reasons. I'm looking at practical and low maintenance for DD operation. And for the same reason, the IVC of 38 is related to maintaining my 6000 shiftpoint.
#34
Even if you want to shift at 6000, you may be better off with an IVC = 40. You may find that you still get more area under the curve. Certainly after the 1-2 upshift, you'll be better off. You might put the cam in with an adjustible chain and experiment.
#36
I looked at an "old" favorite all around cam. The venerable 216/220 114+4.
That one is on a 38 IVC
216/220, .525/.532 114+4
IVO>-2
IVC>38
EVO>48
EVC>-8
ECL>118
OVERLAP>-10
I used that cam and it was really good from idle till 6300 with headers(obvious by EVO being early), I got 397rwhp with MTI ported LS1 heads, bolt ons in my 99 M6.
Point being the trq curve was phenominal for those lobes.
![](http://www.thunderracing.com/images/dynos/216220headsintake.jpg)
#37
Hard to say. I just know that when properly set up, 40k miles on OMC lobes are no problem with PP/PRC/Manley duals shimmed to within .050" of coil bind. Doing this eliminates spring surge and adds to the life of the spring.
#38
Pontiacerator
#39
I've always been impressed that you made 400 rwhp with that cam and S1 heads. I've haven't seen too many repeat that with those soft lobes. You had it dialed in right.
My only point is that with his stall, mild as it is, he may run faster by using an IVC = 40 if it gives him a little higher average torque from 3500 - 6000 rpm at the expense of power below 2500 rpm. Hence the suggestion of an adjustible timing chain.
#40
this thread is an oldie but a goodie ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Say you have a stock stalled 2.73-3.23 geared A4.
What cam specs would you recommend with a peak power of 5800 and 6000rpm shift point. 11:1 compression, stock exhaust manifolds and stock cats? Maximum power under the curve, great idle (700rpm) and emissions legal.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
