Oil path question.
Old Jan 22, 2006 | 07:29 PM
gomer's Avatar
Default Oil path question.
Does anyone have a detailed diagram or explanation of the oiling path on a LS1? I'd like to know, step by step, the oil path after it leaves the oil pump.
Old Jan 22, 2006 | 07:33 PM
Grimes's Avatar
from that famous wil hadzel book:
Old Jan 22, 2006 | 10:09 PM
gomer's Avatar
Excellent diagram!
Anyone else have more to add??
Old Jan 22, 2006 | 10:19 PM
usnskeet21's Avatar
this is a good topic and may answer my question to a post i just started about the lifter orientation relating to which way the port in the lifter needs to face?
Old Jan 22, 2006 | 10:24 PM
Ben R's Avatar
Yeah, I got something to add. The stock oiling system sucks.
Old Jan 23, 2006 | 07:00 AM
gomer's Avatar
The reason I started this thread is that I have a brand new 348 I have installed that is not oiling the top of the engine. Both the front and rear oil galley plugs are in the engine and I have installed two different oil pumps in it. I can pull the filter or the diverter plate above the filter then spin the motor over and it pumps oil out there.. but no oil is getting to the lifters, cam, rockers.. etc. Any thoughts? Btw, the engine is showing "0" oil pressure on the gage.
Old Jan 23, 2006 | 02:22 PM
gomer's Avatar
I found the following description of oil flow, I'm going to paste it in below.
The driver side of the pump casting has a passage to feed pressurized oil through a galley in the block that runs to the back. Before getting to the back of the block, the oil travels down through the oil pan rail to the oil filter, then back up through the rear block cover to the lifter galleys and main bearing galley. From there, the oil follows the standard small-block Chevy split route of through the pushrods to the top of the engine and down to the cam, main, and rod bearings.
Old Jan 24, 2006 | 10:09 AM
TurboGibbs's Avatar
Did you find your problem yet?
Old Jan 24, 2006 | 10:29 AM
gomer's Avatar
Yep
Old Jan 24, 2006 | 11:22 AM
cyphur's Avatar
Originally Posted by gomer
Yep
And? Problem with the block or what? Don't leave us hangin man!
Old Jan 24, 2006 | 11:28 AM
gomer's Avatar
Where the oil pan gasket seals off from the pan into the oil galley in the block, there was a large broken place in the pan gasket, so all of the oil would get pumped from the pump, into the oil filter, then out of the filter.. thru that hole and back into the pan instead of going up the back of the block and into the lifter galley.
Old Jan 24, 2006 | 01:43 PM
TurboGibbs's Avatar
At least it wasn't me this time!
