Lifter tool for cam swap
Old Jan 30, 2006 | 05:29 PM
BLACKBIRD8200's Avatar
has anybody had problems with the wood swelling when the oil has soaked in??
Old Jan 30, 2006 | 05:42 PM
Ωmega's Avatar
I've never had any problems.
Old Jan 31, 2006 | 09:03 AM
magius231's Avatar
Originally Posted by 777
As soon as you crank the car with stock springs and a decent cam (anything over like .550) they will snap or your rockers will break. There is a thing called coil bind. When that happens you are screwed, it doesn't matter, how high you rev the engine.
thus the reason the first thing I said was "check for coil bind"
Old Jan 31, 2006 | 09:10 AM
777's Avatar
777
I understand, however, I wouldn't even use stock springs on an ls6 cam.
