Which ARP heads studs for 6.0L Iron Block
Which heads studs do I need for a 6.0L iron block 408 build? I just want to make sure I get the right ones!
Note: I am looking at the 12 pt. heads studs.
Thanks
Thanks
Originally Posted by 99whitews6
How can I confirm what block I have? Is the year stamped on it somewhere?
Originally Posted by Beast96Z
The part number should be on the back on the driverside. Just below the head deck. Post that number up and someone can tell you if it is old or new.
- and I have searched it and found different years being called out. Most common call out is 02-up.
