Locking the Flywheel?
Old Jan 27, 2006 | 12:57 AM
just-a-z's Avatar
Default Locking the Flywheel?
What is the best way to do this without the flywheel locking tool? I dropped the starter and wedged a screwdriver in, but no luck . Anything will help
Old Jan 27, 2006 | 01:09 AM
NoGamesLS1's Avatar
Are you trying to get the flywheel bolts off? I just used a crowbar in the teeth and had someone else hold it.
Old Jan 27, 2006 | 01:20 AM
just-a-z's Avatar
I am trying to take the Crank bolt off my pulley and need to stop the engine from turnung.
just-a-z's Avatar
I'm doing a Heads and cam swap
Old Jan 27, 2006 | 01:28 AM
DONAIMIAN's Avatar
Set the park brake and put it in 4th gear.
Old Jan 27, 2006 | 01:34 AM
just-a-z's Avatar
that would be the case.......if it was a M6. Sorry, I should have mentioned it is an A4. Thanks for the reply
NoGamesLS1's Avatar
hey when you pull the cam make sure you use something to hold up the lifters. unless you want to fish them out of your oil pan
Old Jan 27, 2006 | 01:38 AM
just-a-z's Avatar
the heads are already off and so are the lifters. The head bolts are clean and everything is ready for the TSP H/C swap. I just can't lock that damn flywheel to save my life.
Old Jan 27, 2006 | 01:50 AM
NoGamesLS1's Avatar
Just read ls1howto.com If the screwdriver doesnt work it looks like you'll have to buy the tool. Autozone might rent something like that.
Old Jan 27, 2006 | 01:52 AM
just-a-z's Avatar
I went on there and there isn't a right up or anything on it. I guess I will have to go to town to get that damned tool. Thanks guys
Old Jan 27, 2006 | 01:55 AM
NoGamesLS1's Avatar
good luck
Old Jan 27, 2006 | 11:29 AM
DONAIMIAN's Avatar
sorry, I saw flywheel and thought it was an M6
Old Jan 28, 2006 | 01:38 PM
DanZ28's Avatar
I popped that round plug on the bottom of the bellhousing towards the driver side and used a crow bar in there. I did this 3 or 4 different times by myself so I know it worked for me fine. I wish I would of owned the tool anyway though..
Old Jan 28, 2006 | 01:57 PM
just-a-z's Avatar
I got it with a screwdriver and got my old cam out yesterday!! Now my block is ready to recieve new heads and a cam from TSP
Old Jan 29, 2006 | 06:14 PM
Bill Bowling's Avatar
I bought a holding tool from another member code4 that worked great.
Bill
Old Jan 29, 2006 | 06:17 PM
just-a-z's Avatar
thanks, but I got it with a screwdriver!
Old Jan 29, 2006 | 09:20 PM
kossuth's Avatar
Another idea for folks that have had this problem is make a holding tool yourself. Get a piece of 1" angle iron about .125" or so thick and drill a couple of slotted holes where the starter holes would be. Get some shorter bolts and lock it in this way. Basically same thing as a flywheel locking tool and you can pick a piece of iron up at Tractor supply for the tune of $10 or so.
Old Jan 29, 2006 | 09:23 PM
Rebelord's Avatar
just-a-z: where in az are ya? yuma here
Old Jan 29, 2006 | 09:33 PM
just-a-z's Avatar
i'm in sierra vista for now
Old Jan 29, 2006 | 10:07 PM
Ωmega's Avatar
Bill
That's what I use too! I wasn't going to post up because I forgot what the guys name on here was. But that thing is awesome.
