need help identifying a camshaft
Old Jan 27, 2006 | 04:52 PM
george88gta's Avatar
Default need help identifying a camshaft
I have a camshaft, in a mailing tube, that is labelled 2003 Vette. Etched numbers on end of cam are 1721 S04 2154 and there is C and 3 stamped there as well. Anyone able to identify this? Is it a GM cam or aftermarket? Thanks,George.
Old Jan 27, 2006 | 05:02 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Congratulations! You are the owner of a cam that has no daddy!
I tried to search on Google for it and it brought up a bunch of german or some other language. Your best bet is to send it to like Thunder Racing for like 25$ and then they will give you a new cam card to go with it.
Old Jan 28, 2006 | 04:24 PM
Looks you are right, orangeapeel, no one has an id for this cam. Guess I will send it out to have it spec'd. Sure not going to install it without identifying the grind.Thanks, George.
Old Jan 28, 2006 | 04:49 PM
2xLS1's Avatar
Stock 01+ LS1 cam
GM Part # 12561721
196/207 .479/.467 116 LSA
Old Jan 28, 2006 | 06:35 PM
Ωmega's Avatar
Originally Posted by 2xLS1
Stock 01+ LS1 cam
GM Part # 12561721
You didn't buy that cam from someone did you?
Old Jan 28, 2006 | 06:51 PM
No, it is lying around the garage. I think someone gave it to my son. He was trying to get me to install it in my new 2002 6.0 crate motor.
Old Jan 28, 2006 | 06:53 PM
Ωmega's Avatar
Oh okay
Old Jan 28, 2006 | 06:55 PM
Stock 01+ LS1 cam
GM Part # 12561721
If I read your post correctly, you are stating that the 1721 is the last 4 numbers and the SO4 and 2154 are not significant to the part number? If this is so, then I believe that this is the same as the cam already installed in my 2002 6.0 crate engine. Good news, one less thing to do before the install in my 1955 Chevy.
Old Jan 28, 2006 | 07:00 PM
2xLS1's Avatar
All GM gen 3 cams I've seen have the last 4 digits of the part # on them. I don't know what the other #s are. Could be date codes or lot #s.
