Swapping A Ls1 For 6.0
Old Jan 29, 2006 | 12:41 AM
dnkynrbk's Avatar
Default Swapping A Ls1 For 6.0
Just need some help built a 6.0 lq4 and putting it in my 98 ta is there anything that I have to do to complete the swap. Someone told me that I would have to drill and tap the a place for the alternator and this was out of a truck and someone said I had to change the pilot bearing. let me know thanks
Old Jan 29, 2006 | 11:54 AM
67Ranger's Avatar
tap a hole for the alternator, there is a blank spot, so it isnt too hard to do. Relocate one of the ground wires, on the LS1 it goes to the block, and there isnt a hole for it on the 6.0L. (I put mine with the motor mounts.) and putting a pilot bearing in there would be good too, since mine didnt have one whenever i got it.
Old Jan 31, 2006 | 12:26 PM
dnkynrbk's Avatar
so basically that is it.
Old Jan 31, 2006 | 09:32 PM
67Ranger's Avatar
thats about all the differences... Also, the AC bracket was different on mine, but i just used 3 bolts, instead of 4, and its held alright so far.
Old Jan 31, 2006 | 10:52 PM
SUX2BU's Avatar
Also find a way to offset the 100 lbs you are adding to the front end.
Old Feb 1, 2006 | 11:48 AM
67Ranger's Avatar
yeah, that too... those things are really heavy. The blck alone seemed like it weighed about as much, if not a little more than my entire 5.7 shortblock.
Old Feb 1, 2006 | 03:58 PM
VTC_WS6's Avatar
I thought it was ~60-70lbs in difference?
I'm debating between a freshly rebuilt LQ9 longblock or rebuilding my LS1 for my '00 WS6, any pointers?
Old Feb 1, 2006 | 05:47 PM
SUX2BU's Avatar
Its more like 85-100 if i remebere correctly.
If your gonna be into racing at the track at all i would say 5.7. Unless you are planning on going crazy with the spray or boost. only then would the iron block be worth it.
Old Feb 1, 2006 | 06:56 PM
GDM Z28's Avatar
you cant use the lq4 oil pan or oil pick up eiher.
you need to use the ls1 pickup and pan.
Old Feb 1, 2006 | 07:25 PM
VTC_WS6's Avatar
Interesting stuff, have you run a iron block in your car before? This will be primarily a daily driver with the occasional trip to the strip. I figure a cam, bolt-ons, LS6 intake, should be happy with ~380-400whp and maybe a little squirt on top. Now how would you compare the same with an aluminum 346?
Old Feb 1, 2006 | 07:56 PM
n2o junkee's Avatar
I know your alt. should fit fine. as far as the pilot bearing goes I have no idea
Old Feb 1, 2006 | 08:00 PM
Dales396lt4's Avatar
It is only 60-70lbs in difference, I have both on the stands waiting to go in 1. 408ci (LQ9) 2. 346ci (LS1)
Old Feb 1, 2006 | 08:11 PM
VTC_WS6's Avatar
Yea that's what my book tells me as well. It's trying to decide whether or not it's worth the weight that sucks!
Old Feb 1, 2006 | 08:31 PM
SUX2BU's Avatar
Yeah i blew up my original 5.7 and put in a stock 6.0 shortbock. I milled my LS1 heads to get the compression back up and threw a fairly big cam in it. it made good power 424/420 thru an M6. And it ran decent 11.7's @ 118 weighing ion at 3555 lbs. But i decided to go really fast and the easiest way to go fast is to lose weight (that and i couldn't compare my car to anyone cause i had 18 more cubic inches). So i had enuff parts layin around to have a 5.7 rebuilt, threw that in with stock heads and a stock cam. It has run a best of 11.04 @ 122 weighin in at 2960 with me in it.
Losing weight is the BEST mod i have ever done to my car. And i can't justify adding all that weight to my car especially in the front.
If you really want a 6.0 why not get an LS2 block? they are only about $300 more than the iron block.
Old Feb 1, 2006 | 08:40 PM
VTC_WS6's Avatar
Talking
Good, I'm glad I'm hearing first hand knowledge finally! One of the reasons why I pondered the LQ9 so much was because I could get one for $150, complete long block, then just have it freshly rebuilt (needs one) and go from there. But at the same time somebody locally has an LS1 shortblock for $1300 which is already set to be dropped in, just carry over my heads and buy a new cam which I woulda bought for the LQ9 anyways. I guess really it comes down to is the extra 18cubes worth the 70lbs you know? And I dunno, I think I'm leaning more towards the LS1 now anyways, keeps things simple. Keeps the weight down on an already heavy car and I think I feel a little better about reving a LS1 bottom end to 6500 than I would an LQ9 with the heavier rods and pistons.
Old Feb 3, 2006 | 01:24 AM
dnkynrbk's Avatar
hey guys thanks here is my set up will be done next week
6.0 bored .30 over , diamond forged pistons, eagle forge rods, magic stick cam 610 lift ls6 intake, oem replacment lifters patriot stage 3 heads 64cc chamber 11-1 compression with a 100 shot of TNT wet kit. thanks for the help does anyone know about changing the pilot bearing for a automatic thanks
Old Feb 3, 2006 | 01:28 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Another way to remedy that is to !A/C.
Old Feb 3, 2006 | 11:29 AM
SUX2BU's Avatar
Auto's don't need pilot bearings.
Old Feb 3, 2006 | 11:47 AM
dnkynrbk's Avatar
so just pull that one out or leave it in the block and crank cam out of a truck
