balancer seal
Old Jan 29, 2006 | 02:10 PM
BOTTLE ROCKET's Avatar
Default balancer seal
Did a run on the dyno and found an oil puddle under the car. Drove home and found that the bolt had backed out and the pulley had moved forward about 1/4 inch. There were just a few drops after the drive home. Do yo think my seal will need replacing. and if so, has anyone replaced one without removing the cover?
Old Jan 29, 2006 | 08:52 PM
THIRD-GEN92's Avatar
it happend to me also, same thing after some 1/4 mile runs. Did you remove the bolt at any time? if you did you need to replace it with a new one and it well fix your problem.
Old Jan 29, 2006 | 08:58 PM
JMBLOWNWS6's Avatar
Ya you will have to remove the balancer and replace the seal. And either use a NEW OEM bolt or the ARP bolt.
