Rod bolt question
Old Jan 30, 2006 | 09:25 AM
80superbu's Avatar
Default Rod bolt question
Are the rod bolts in a stock LS1 motor pressed in? I'm going thru the motor and would like to add some ARP rod bolts. I know the older SBC rod bolts were pressed in which meant completely disassembling the motor to change the bolts.
Thanks
Old Jan 30, 2006 | 09:37 AM
777's Avatar
777
The rod bolts are a bolt just like any other. Just unscrew them. I'd use Katech's bolt's if I were you. They are designed to be a direct replacement. Although you should be fine with arp's, I believe they recomend checking for roundness and what not.
Old Jan 30, 2006 | 09:49 AM
PREDATOR-Z's Avatar
Katech the only way to go. No huff or fuss, just bolt on and trq to 50 lbs.
Old Jan 30, 2006 | 09:55 AM
80superbu's Avatar
Thanks..it's a stock bottom end motor that had 60k on it, was a girls car with no mods so I'm not overly concerned it was pushed real hard. I was just making sure they didn't need to be pressed in.
Thanks all
Old Jan 30, 2006 | 10:01 AM
80superbu's Avatar
OK..a quick question. Why does Katech charge $153 for rod bolts when I can get the ARP's for less than 1/2 that???
Old Jan 30, 2006 | 10:30 AM
PREDATOR-Z's Avatar
Because they are the ones that did the R&D and the only ones that are GM approved (ASA program) and the only ones that make direct PnP replacements and garantee them as such.
Old Jan 30, 2006 | 10:31 AM
J&J Speed Shop's Avatar
Cause Katech are a bolt in an go, where as the ARP bolts most likely need to have the big end honed
Old Feb 13, 2006 | 06:03 PM
BriGuy's Avatar
Where can I buy the Katech bolts from?
Looking to buy ASAP!
Old Feb 13, 2006 | 06:39 PM
Gary98Z's Avatar
You can buy them direct from Jason at Katech.
586-791-4120 x234
Old Feb 13, 2006 | 09:00 PM
BriGuy's Avatar
Thanks!
