Whered my torque go?
QUOTE=PREDATOR-Z]Well, I would say you're running a bit lean, try fatening a little and see if it improves.
Also, what was your lifter preload?[/QUOTE]
QUOTE=LSGunZ28]You changed your heads you said... it might have affected your compression ratio, which can give you less torque, typically, your compression ratio was probably less than it was with the older heads. I may be wrong, but this could be the problem.[/QUOTE]
that is certainly odd...
I cannot think what the problem is, especially you losing torqu and it being moved higher, usually it just moves the powerband, but no loss....
I honestly cannot think of why this could have happened. sorry dude
