Opps !! blowed something in my engine!!!??!
Old Jan 30, 2006 | 01:58 PM
prostock_bigblock's Avatar
Default Opps !! blowed something in my engine!!!??!
went to track yesterday , on the last run i hit the limiter very hard and engine started shaking like hell , I dont hear any ticking at all . However, tepmreture is normal , oil pressure is normal to , car doesnt smoke as well . the only thing is it shakes and SES light is on .
I think that I blowed a head gasket or if it worser than that I could probably burn a piston .
What do u think guys?!??!
Old Jan 30, 2006 | 02:01 PM
Zero30's Avatar
u may have bent some of the pushrods
Reckless's Avatar
Super Moderator
Also may be a broken valve spring or bent/broken pushrod.
Old Jan 30, 2006 | 02:04 PM
ls1charged's Avatar
You dont have a blown head gasket if the temperature is fine.Pull the valve covers and check the rockers,pushrods and springs to start.But if you have good oil pressure its prolli not that,BUT the pushrods could be bent just enough so its causing a problem.Check your plugs and pulleys as well.
Old Jan 30, 2006 | 02:06 PM
but do u think that I should hear some ticking at least with a bent pushrod or a broken springs?
Old Jan 30, 2006 | 02:07 PM
i well do thanks for your input .
any more out there?!!??
Old Jan 30, 2006 | 02:18 PM
Greg Fell's Avatar
as they said...its probably a spring or pushrod.
Old Jan 30, 2006 | 02:52 PM
Xtnct00WS6's Avatar
It seems unlikely that it would be an internal problem if there's no ticking. I thought there was a ticking sound that would come from a bent PR? The first thing I thought of was the engine mounts if the engine is shaking really bad. I would think the mounts would be pretty hard to break though. Just tear into it and take a look see.
Old Jan 30, 2006 | 03:01 PM
ArKay99's Avatar
Could be one or more bent valves. You may have floated, kissed a piston, and now aren't getting a good valve seal, causing poor to no compression in 1 or more cylinders. You should do a leakdown test to see if that is the problem.
Old Jan 30, 2006 | 03:05 PM
Super Speed's Avatar
I thought hitting the rev limiter wasnt TOO bad for your car since its there to save it
Old Jan 30, 2006 | 03:16 PM
GuitsBoy's Avatar
check your plugs and wires since thats easy enough. Might have killed an electrode on one of your plugs.
Old Jan 30, 2006 | 03:19 PM
Reverend Chaos's Avatar
could be something as simple as a fouled spark plug....keep it simple!
Old Jan 30, 2006 | 03:26 PM
Patrick G's Avatar
LS1 Tech Administrator
Check the fuse that goes to your MAF (20a ENG SEN). If it blows, your car will run like you're saying.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 30, 2006 | 03:27 PM
6spdpewterZ's Avatar
Old Jan 30, 2006 | 03:28 PM
Thats what I well be doin on Friday after my tests in college .I will keep it simple and check my plugs , wires , pulleys . Found nothing I well pull the valve cover and check for bint pushrods ..etc . I wish its a valve springs or pushrods so I can do a cam swap
Old Jan 30, 2006 | 03:30 PM
Originally Posted by 6spdpewterZ
very nice!!!
Old Jan 30, 2006 | 04:00 PM
Viper's Avatar
Don't drive it anymore till after the tests, IMHO.
Old Jan 30, 2006 | 04:12 PM
If i am driven it I will take it to a mechanic.
Old Jan 30, 2006 | 06:33 PM
Ouchburns's Avatar
Your in college?
