main torque sequence just checking
Old Feb 1, 2006 | 08:24 AM
12thstreetjunkman's Avatar
Default main torque sequence just checking
I have a friend copying some pages from a service manual, but in the mean time, I was wanting to go ahead and plasti gauge the mains, just to make sure this is the correct sequence right? It doesn't say it but I would imagine you would want to run everything through the first pass, then go back and do the final pass on 1-10, then 11-20. Thanks for the help
1-10 15lbs
21-30 18lbs
11-20 15lbs
then
1-10 additional 80 degrees
11-20 additional 53 degrees
going by the diagram & info in this thread
https://ls1tech.com/forums/showthrea...orque+sequence
