easy 500 rwhp?
You'll need to swap out that engine for bigger cubes or just add on FI or nitrous.
however, the easier way is with cubic displacement. but big cubes is no guarentee for 500rwhp either. the right combo of parts is also neccessary, your power is going to come from a good h/c/i combo matched to your application and powerband.
to all you
Yeah you really know what your talking about. That why you posted this thread in the first place. If you already knew the answer to your question then why did you ask it?
Oh thats right because you had no clue what you were talking about thats why you posted this....
"what is the easiest/cheapest way to 500 rwhp all motor. nitrous will be add on top of that. i was thinking that ls6 heads ported and ls6 manifold ported to match with all the bolt ons and a cam would get me there. i want something i can still cruise in with decent street manners and take it to a track day every once in a while."
Yeah you really know what your doing. LS6 heads, with LS6 intake, bolt ons and a cam. Not a certain cam just a cam, but one with decent street manner's.
I would have never posted this reply if you wouldn't have been a dick head to the other members. If you newby *** would have used the damn search button you wouldn't have posted a retarded thread. Dont be a dick to the member that are acturally giving you good advice just because they are being a smart ***.
Do yourself a favor and get in good with some of these guys and learn so your next threat dosen't make you look a dumb as this one did.
I know JRP already stated as much but dang . . . some of you guys posting in this thread have been around a while . . . I at least expected Lyle to know as much
500 rwhp N/A 346 is by NO MEANS easy; but it is doable.
I'll let you guys know how close it is on my set-up in 2 weeks
Lyle, when are we gonna run motor for motor??
Then fly cut your stock pistons and add rod bolts.
Fast 90/90 intake and a lot of gear
Then next match your combo with a lager custom cam.
It can be done if you match up the correct combo, look at Patrick G. he is close with only a small set of AFR 205 heads and mid size cam.
Just wait, with all these new heads coming out now and new intake being designed; there will be a lot more 346ci/500hp street car out there soon.
Bob
not cheap though. not gonna happen cheap. and with a 109 LSA, you'll be prone to intake backfires if the dope isnt properly tuned and it will take you more dope to make the same power because so much of it will get sucked right out the exhaust valve during overlap.
Scott
Note: The red line is customer's previous heads/cam package from another shop.
It's been done and can be repeated.
Details on the car:
1998 Camaro, MN6.
3.5" Alum Driveshaft
9", 35 Spline Axles, 4.10 Gears, Spool
TTP Stage 4R Heads/Cam Package (Hydraulic Roller)
LSX 90mm Intake + NW 90mm TB
Kooks 1 3/4" to 1 7/8" Stepped LTs
True Dual 3" to 2.5" w/ Dynomax Ultra-Flo Mufflers
Stock Bottom End w/ Pro-Series Rod Bolts only
93 Octane Pump Gas
I would say this combination would make around 515-520rwhp easily on a stock rearend.
Good Flowing Heads (AFR 225's etc.)
Custom Cam Spit duration, Wide LSA for NOS Application (EDC, OR FMS etc.)
Fast 90/90 Intake manifold
Final Compression Ratio around 12:1 to 12.5:1
and ofcourse all bolt-ons and free mods and lots and lots of tuning (HPtuners).. this setup will be reliable and about 500-550rwhp (all motor) depending on how wild the H/C will be + u can also spray 100-250 Shots of Nitrous depending on the spark plugs and how much degrees of timing ur running.
note: you can do 500rwhp in a 346ci (very wild H/C setup), BUT:
1. it wont be reliable
2. it wont be a good daily driver
3. it would require a BIG stall
4. it wont have good torque
I would have to agree!
Does anyone with 4.10's or higher think they would have a problem with torque??? The problem is hooking up, not too little torque. As for the big stall, get an M6! If you don't have any torque problems, and you've got a good tune, where's the driveability issue? Also, I suspect a lot of guys would say "daily driver" can be a wild ride; can I get an Amen, here?
150 wet shot.
408 iron block
Check out LME (sponsor). They build quite a few of these motors.
You should get 500 rwhp with the right set of heads/cam combo with a 408.
Other than that, its hard to get there with a 5.7L unless you go with a solid roller cam. Then there goes your streetability...
