Hydraulic Lifter - Is there to manually pump it up?
Old Feb 2, 2006 | 05:34 AM
vettenuts's Avatar
Default Hydraulic Lifter - Is there to manually pump it up?
I am going to be installing a set of Morel lifters when I put on my Dart heads. I have read here that the pushrod cup sits higher from the roller than the stock lifters so it will be necessary to also change pushrods. I want to do a swipe test with checking springs.
Is there a way to fill the hydraulic lifter so that the plunger won't deflect during the swipe test? I am wondering if I submerge it in oil if I can operate the plunger and pump up the lifter. With a dial indicator on the valve I should be able to tell if I am getting full lift.
Old Feb 2, 2006 | 12:06 PM
nuzee's Avatar
Use a "trigger-pump" oil can to pre-oil the lifter. Soaking lifters is hit or miss. I don't know about Morel lifters, but the stock lifters bleed down quickly. Be ready to do your swipe test asap and to take your measurements on the first revolution.
I messed with measuring lift at the valves to verify rocker ratios. I was surprised to see how quickly the lifters bleed. I was able to crank the engine over a few times to pump them up again.
Old Feb 2, 2006 | 12:11 PM
777's Avatar
777
A check spring probably wouldn't be enough pressure to cause the lifter to bleed down. Also, since pushrods come in .025 increments you don't have to be 100% exact.
Old Feb 2, 2006 | 06:00 PM
vettenuts's Avatar
Yes, I am using check springs with either shoe polish or white out so it will wipe off easily with little pressure.
Not sure I follow the procedure to pump up the lifter
Old Feb 2, 2006 | 07:11 PM
nuzee's Avatar
Squirt the oil into the hole on the side of the lifter until it is full.
Old Feb 2, 2006 | 07:28 PM
Greg Fell's Avatar
There should be enough spring pressure to keep them pumped up using a check spring.
Old Feb 3, 2006 | 07:32 AM
vettenuts's Avatar
That's what I wasn't sure of, I don't have my Morel's yet they are backordered
Worth the wait though
