G5x4 or Trex
Old Feb 3, 2006 | 09:41 AM
CRASH Bandicoot's Avatar
Default G5x4 or Trex
Old Feb 3, 2006 | 09:46 AM
1fastz28nx's Avatar
What size are your valves?
Old Feb 3, 2006 | 09:51 AM
Old Feb 3, 2006 | 11:14 AM
BAKED's Avatar
With the stock bottom end you are not gonna be able to take advantage of either one. Well not very many times anyway. I would get a good set of rod bolts if you are dead set on running one of these. If not then I would step down to an X2 or X3. JMO
Old Feb 3, 2006 | 11:25 AM
Matt D's Avatar
Retired Street Racer
Trex. It will make more power than the x4.
Old Feb 3, 2006 | 12:25 PM
I see that your running the x3 in your car from your modlist, how do you like the power? does it pull through the powerband? My car is decent now NA with a small cam and I just want to see how fast I can go on stock bottom end.
Old Feb 3, 2006 | 12:30 PM
The1N_only's Avatar
i would go with the t-rex and not look back , it was designed with stock heads in mind... there is a few people here running mid to high 10's with that cam and stock head
Old Feb 3, 2006 | 12:31 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You need some rod bolts if you are gonna take full advantage of a 24x .600+ cam.
Old Feb 3, 2006 | 12:56 PM
King James's Avatar
If its an 01 or 02 car it should have stronger rod bolts from the factory, correct?
Old Feb 3, 2006 | 01:01 PM
4bangermustang's Avatar
x4 will idle better then the T-rex. It's also makes good power and designed to work with the stock heads.
Rod bolts are not required at all. Jugger ran the x4 without rod bolts....
Brian
Old Feb 3, 2006 | 01:08 PM
oh, there's a few guys around here running low 10's with the x4..
Old Feb 3, 2006 | 02:55 PM
BAKED's Avatar
I like it pretty well, I wish it had a little more bottom end but once it gets around 3K it's an animal. I wouldn't trade my X3 for a X4 or a T-Rex to be honest.
Old Feb 3, 2006 | 02:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not true. Either one of these cams will need a tune for what is trying to be achieved. You can have a t-rex with a great idle if you have a proficient tuner.
