Please explain pros/con or a solid roller vs hydraulic roller setup
Old Feb 6, 2006 | 01:49 AM
NoGamesLS1's Avatar
Default Please explain pros/con or a solid roller vs hydraulic roller setup
Just as the title. Whats the difference between a solid roller and hydraulic roller setup. Thanks
Old Feb 6, 2006 | 01:58 AM
Beast96Z's Avatar
A solid lifter allows you to run a much more harsh lobe profile as compared to a hydraulic. You also don't have any "give" in the solid lifter allowing you to use 100% of the camshaft. Only downfall to the solid is getting the lash set properly and maintaing the lash at oil change intervals. Also th ecost is a little more on the solid.
Old Feb 6, 2006 | 08:41 AM
jyeager's Avatar
Why does the lash keep needing to be reset? What is it that wears or loosens?
Old Mar 14, 2006 | 11:15 PM
StangEaterSS's Avatar
I was also curious on solid roller set ups. is it really that big of a problem with the lash adjustment?
