Damn it Compression= 0 !!??
Old Feb 8, 2006 | 07:11 PM
cantdrv65's Avatar
Post
Originally Posted by prostock_bigblock
thanks for the input guys , i will do what u all mentioned above , and re-compression test one more time .
i will tell what will happen tomorow.
Remember make sure the valves are in the closed position first before checking compression... I highly doubt you damaged a piston due to an over rev...
Old Feb 9, 2006 | 08:28 AM
Peacock's Avatar
You mean leakdown, right? Compression is tested while the engine is cranked...
Old Feb 9, 2006 | 03:48 PM
cantdrv65's Avatar
Post
Yep I meant leakdown... I assumed he was performing a leakdown test, my bad. You know what they say assumptions are the root of all evil.
Old Feb 9, 2006 | 04:43 PM
prostock_bigblock's Avatar
Thanks for the info CANTDRv65 , by tomorow I will know whats really goin on with my motor.
Old Feb 9, 2006 | 07:18 PM
zupmanZ28's Avatar
One thing, did you test other cylinders, or just #8? I just wanted to rule out a tester malfunction. I know it's a long shot, but i didn't see any mention of testing other cylinders.
Eric
Old Feb 9, 2006 | 08:09 PM
did test all of them 8 was the only one with zero , untill know looks like the heads r the problem but by tomorow I will till u guys what was wrong.
by the way this is good chance to look for a new set of budget heads , what do u think guys?
any opinions?
Old Feb 10, 2006 | 05:37 PM
okk finally found out that the valves r damaged , so problem was in heads .
Thanks for all the inputs guys......
Old Feb 10, 2006 | 08:00 PM
cantdrv65's Avatar
Post
any opinions?
I just ordered a set of TSP's PRC Ls6 heads....There is a vast wealth of good cylinder heads out now to choose from....
Old Feb 13, 2006 | 09:16 PM
M6WS6's Avatar
I took head off of my car to see what went wrong, Not to horrible of a job, be prepared for some bloody hands tho trying to get the rear bolts
