ms3 prc heads and out of injector?
Old Feb 7, 2006 | 08:55 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Lithium
I went with some SVO 30# injectors myself with the ms3/prc combo...
Lol and how is that working out for you?
Old Feb 7, 2006 | 08:57 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Couldnt ask for anything better. Thank god I was able to get them on in time lol.
Old Feb 7, 2006 | 09:01 PM
camarokid94's Avatar
No really the 30 SVOs are really alittle bigger in an LS1 LIke they said a 34 or something but, cause 42s are almost the same price theres no real reason not to get them. they will ahve a lower duty cycle (wich means not have to work as hard ( possible last longer humm)) and there is no down side to a bigger injector.
you can always upgrade , add a dry kit whatever and you will be ok with the 42s
Old Feb 8, 2006 | 06:22 AM
PREDATOR-Z's Avatar
Over injecting a motor is unnecessary and counter productive.
The fuel distribution in a bigger injector is different. What you want is the best atomization (the smallest particles) of fuel you can have to mix with air for best results.
While bigger injectors will help at top rpm feeding, the bottom ones will suffer and that is where you spend most of your time.
Please get off this bigger is better. In a motor you need the RIGHT part not the biggest you can fit to make it go faster.
Old Feb 8, 2006 | 09:59 AM
35thls1ss19's Avatar
so what do u suggest for my heads cam setup and a am also sprayin a wet kit... that dotn matter right?
Old Feb 8, 2006 | 10:43 AM
PREDATOR-Z's Avatar
SVO 30's
I see you have a Racetronix pump, did you get the harness with that?
If not, get the harness, that will get you a 62 psi at the rail.
And for the future, get a regulator at the rail with a return line, that way you can adjust for presure at WOT and maintain that 58 psi needed.
Wet doesn't need bigger injectors.
Old Feb 8, 2006 | 10:51 AM
NOS USER's Avatar
Guys with the MS3 + PRC 5.3 HEADS what`s the purshods length you used?
Old Feb 8, 2006 | 11:09 AM
SVO 30's
yea i got the harrness with it and thats what i have at the rail is 62psi
Old Feb 8, 2006 | 11:38 AM
PREDATOR-Z's Avatar
That is exactly what I'm talking about.
just for your info, I run SVO 30s with PNP racetronix 255, harness and FPR at rail AND I shoot up to 200 dry.
NA I'm at 72% duty at WOT and I only max out 97% on a 200 shot (for a measely 10 sec).
That is ~ 620 rwhp
That is to show you how important keeping 57/58 psi at wot is or your injector size.
Old Feb 8, 2006 | 11:42 AM
just for your info, run SVO 30s with PNP racetronix 255, harness and FPR at rail AND I shoot up to 200 dry.
That is ~ 620 rwhp
any perticular regulator you suggest? and am i goin to need that right away when i tune the car? tahnks again
Old Feb 8, 2006 | 11:44 AM
PREDATOR-Z's Avatar
I run a Racetronix one.
No, since you're shooting wet, I needed it more because i'm dry (dual stage)
Old Feb 8, 2006 | 11:49 AM
  #32
ok cool thanks again for all the help... now i just go to get my car runiing and i am comin for u haha
Old Feb 8, 2006 | 11:52 AM
  #33
PREDATOR-Z's Avatar
MS3 VS Torquer V2 shootout
Old Feb 8, 2006 | 12:13 PM
  #34
white2001s10's Avatar
Originally Posted by Jpr5690
just got my ms3 cam and prc heads install finished and when i went for a tune the car ran lean as hell (15:1) and i had a 98%+ injector duty cycle... i did'nt think i needed bigger injectors for a h\c swap but its lookin that way....
How were you measuring your AFR?
Was this being tested at the tailpipe after the cats?
Old Feb 8, 2006 | 12:18 PM
  #35
Old Feb 10, 2006 | 10:49 PM
  #36
Jpr5690's Avatar
no cats @ tailpipe
Old Feb 10, 2006 | 10:50 PM
  #37
Jpr5690's Avatar
i got a retune scheduled with people who actually know what their doing next weekend and i have new injectors that just cam in today ill post up how this turns out im thinkin it lookin at another 30+ hp on the way
Old Feb 18, 2006 | 02:26 AM
  #38
Mr.Nitrous's Avatar
im just gonna get a set of 42's and call it a day ... i was just a little concerned but hell since its common for this to happen its all good .. hopefully ill have real numbers in a week and ill post em up
It's funny how you think I was WRONG and RIPPED you off. Yes, I should spend time on tuning a car with way to small of injectors. Yea right! Like I said get bigger injectors and I would redo it for you, to bad you didn't listen to me and then ran your mouth. Guess you can't please everyone!
Old Feb 18, 2006 | 09:56 AM
  #39
walker94z28's Avatar
Well, I dont have any dyno numbers yet. I just wanted to post up and tell the man congrats on his cam and heads install. Good choice on cams, I have one and sick uptop power. Good luck on the injector issue cause I am sure I have the same issue, just havent checked it yet.
Old Feb 18, 2006 | 12:11 PM
  #40
Jpr5690's Avatar
Pm'ed Ya Dennis, Glad To See I Can Finally Get Ahold Of Ya
