ms3 prc heads and out of injector?
tq converter lockup moved up to 55 mph
revlimiter @7000 shifts @ 6600
lock up clutch apply is quicker
injector tables changed for 42's
a\f adjusted to read 13.0 wot
idle aif flow table changed (very weird numbers to start with)
changes to the pe tables??
i know theres alot more but im not that edcuated (yet) to understand all the work that went on yesterday
as of now my only problem leftover form the intial install is my tcs wont work intermittently.... all i know about this is it throws no codes (just turns off) and if i take the car to high speeds it turns back on but after a few min at lower (arround town) speeds it turns back off ??????? anyone wanna take a guess????
Got Numbers?
Sounds like some monster numbers. Not that many cars make 430 unlocked so I know you will be a happy guy and should be well into the 10`s n/a
Defintly post up the final numbers when ya get em.
Sounds about right to me too.
Had you not flexed your e-**** on here you would know your numbers right now.
Good luck going for 430.
I apolgise for any inconvience i may have caused
-john
